#11 |
Danke erhalten: 3.420
Heli-Professional AG will launch the new SOXOS STRIKE 7.1 on November 26, 2021.
When developing the soXos STRIKE 7.1, the main priority was to increase the tail speed. The gear ratio is new at 1: 5.05. This means that very good tail performance can be achieved even with low RPM. As a result of the redesign, we have also made further improvements / changes such as the one-way, belt tensioner, canopy lock, rotor head damping, tail hub damping, etc. The 5 different coloured canopies, which also come with matching rotor blades, round off the new development. This enables us to fully cover your needs. The new soXos STRIKE 7.1 is not just a helicopter but is an extremely convincing product that claims absolute market leadership. The canopies and the enclosed rotor blades are available in the following colours: a striking neon yellow, neon orange, a stylish white, a very beautiful green and a noble red. The canopies were deliberately made with a matt surface. Timely, noble, and stylish. So, you can let your personality flow into your own equipment and vary the colour of the helicopter. Years of experience, enormous powers of conviction and many ingenious development ideas have gone into this helicopter. For the soXos STRIKE 7.1 to become this unique helicopter, a whole team worked in the background with specialist knowledge and excellent competence. You can order the soXos STRIKE 7.1 from your specialist dealer from Friday, November 26th, 2021. Become a facebook-member of soXos Pilots and you will get first-hand news and important information about the soXos Heli! We wish you inexhaustible pleasure with the soXos STRIKE 7.1 YOUR soXos TEAM |
#12 |
Quelle live Hobby
899€ https://www.live-hobby.de/out/media/...KE7.1_v1.0.pdf soXos Strike 7.1 der Alleskönner der 700er Klasse. Bei der Entwicklung des SOXOS STRIKE 7.1 war die wesentliche Priorität, die Heckdrehzahl zu erhöhen. Das Übersetzungsverhältnis ist neu bei 1:5.05. Damit kann selbst bei «low RPM» eine sehr gute Heckleistung erzielt werden. Durch die Rekonstruktion haben wir auch gleich weitere Verbesserungen/Änderungen wie Freilauf, Riemenspanner, Hauben-Verriegelung, Rotorkopfdämpfung usw. vorgenommen. Der STRIKE 7.1 ist mit 5 verschiedenfarbigen Hauben, bei welchen auch gleich die farblich passenden Rotorblätter beiliegen, erhätlich und runden somit die Neuentwicklung ab. Der neue SOXOS STRIKE 7.1 ist nicht einfach ein Heli, sondern ein überaus überzeugendes Produkt. Die Hauben wurden bewusst in einer matten Oberfläche hergestellt. Zeitgerecht, edel und stilvoll. Somit kann man die Persönlichkeit bei der eigenen Ausstattung einfliessen lassen und bei der Farbwahl des Heli variieren. Damit aus dem SOXOS STRIKE 7.1 dieser einzigartige Helikopter wurde, arbeitete im Hintergrund ein ganzes Team mit Fachwissen und exzellenter Kompetenz. In diesem Helikopter stecken jahrelange Erfahrung, enorm viel Energie und geniale Entwicklungsideen. Technische Spezifikationen Gewicht ohne Komponenten und Blätter: ca. 2180g Rotorblattlänge: 685 - 710mm Heckrotorblattlänge: 105mm Heckrotor Übersetzung: 1:5.05 Haupt-Getriebe Übersetzungen: 7.94 – 10.06 (9.43 im Kit enthalten) Maximale Grösse des Motors: Ø 63mm, Höhe 64mm, Motorwellenlänge von 20 – 56mm Maximale Abmessung des Antriebs-Akkus: Breite 62mm, Höhe 68mm, Länge 350mm Verbesserungen/Änderungen zum STRIKE 7 Freilauf, Riemenspanner, Hauben-Verriegelung, Neu-Gestaltung des Heckrohrs, Rotorkopfdämpfung Heckdrehzahl: 1:5.05 Mögliche Getriebe Übersetzungen (Ritzel sind erhältlich für 6mm oder 8mm Motorwellen) 15 Zähne: 10.06 16 Zähne: 9.43 (im Kit enthalten für 6mm Welle) 17 Zähne: 8.87 18 Zähne: 8.38 19 Zähne: 7.94 Baukasteninhalt SOXOS STRIKE 7.1 Kit Motorenritzel 6 und 8mm für Motoren von 520-560KV/12S Akkuplatte Aluminium-Servohebel passend für alle gängigen Servotypen Kabinenhaube in der Farbe Ihrer Wahl Rotorblätter 1st-RC 690mm, in derselben Farbe der Haube Heckrotorblätter 1st-RC 105mm, in derselben Farbe der Haube Anleitung Empfohlene Komponenten – nicht im KIT enthalten - Flybarless-System - Regler: 12S ab 130A - Motor: 700er - 850er Klasse mit 450 - 560KV / 6mm oder 8mm Welle Motorwellenlänge von 20 – 56mm (Maximalgrösse Motor: Ø 63mm, Höhe 64mm) - Taumelscheibenservos 3 St.: min. 14kg/cm - Heckservo: min. 6kg/cm - 12S Akku 4'000 - 6'500mAh (Maximalgrösse Antriebs-Akku: Breite 62mm, Höhe 68mm, Länge 350mm) - Sender / Empfänger |
#13 |
Danke erhalten: 631
Schön zu sehen das sie jetzt endlich "zugeben" das der 7er Schrott war.
Im Video sieht man davon wie immer nichts. Mfg. Toni
Equipment |
#14 | |
Danke erhalten: 110
Würde ihn sicher nicht als " Schrott" bezeichnen. Sämtliche Produkte wären ja dann auch "Schrott" da jedes Produkt verbessert oder geändert wird. das ist normal. Und ein Umbauset für den Hero wurde ja auch angeboten,das ich aber nicht eingebaut habe. Würde mir den Neuen Strike sofort wieder kaufen,fliege aber keine 700 er Helis mehr. Viel Spass mit dem Soxos. Gruss Hans |
#15 | |
Danke erhalten: 631
Habe ihn ca. 68 Flüge gehabt bevor er wegen GR18 Ausfall runter ging. Dabei musste ich 3x die Blatt Schrauben wechseln (Krumm), nach ca. 20 Flügen hat sich der Riemen geteilt. Prototyp umbau auf 8mm und Problem war weg. Starker Kopfdämpungs Abrieb. UND die mangelnde Heckübersetzung. Hier gab es später auch einen "Umbausatz" wo das viel zu kleine Riemenrad noch weiter verkleinert wurde. Riemen Lebensdauer lässt grüßen. Ferner was heißt lange ? viel ? Die 68Flüge waren bei mir in ca. 2-3 Monaten wobei der zwangsstillstand noch abgezogen werden müsste. PS: Er wurde als LOW RPM Heli beschrieben ohne Angabe der Übersetzung und jetzt sieh ihn dir mal an 5,05. Riemenspanner (top), 26er oder so Riemenrad hinten (top), jetzt sollte auch der 6mm Riemen halten. Also muss an meinen pkt. was dran sein, sonst würde nicht nach nur 2 Jahren ein update kommen. Mfg. Toni PS: optisch, fliegerisch und auch vom Betriebsgeräusch her, hatte er mir sonst super gefallen
Equipment Geändert von heli56 (25.11.2021 um 09:55 Uhr) |
#16 |
Danke erhalten: 1.866
#17 |
Danke erhalten: 110
@ Heli 56
Ich weiss die Anzahl Flüge nicht genau,dürfen so 50-80 gewesen sein. Mein Flugstil war so F3C mässig. Ja eben wie du beschrieben hast: Für meine Ansprüche hats gut gepasst. |
#18 |
Danke erhalten: 39
Ich hab mir einen bestellt bei LH…
Ist bis 30.11. Aktion für 799 inkl Blätter
...forced to work, born to fly... |
#19 |
Danke erhalten: 1.032
+1
T12FG, T18SZ, DS-12 und eine ausreichende Anzahl Helis |
#20 |
Danke erhalten: 110
Zurück zu: Sonstige Helis
Neuer Soxos Strike | heli56 | Sonstige Helis | 2 | 14.11.2021 16:46 |
Soxos Strike 7 Vibrationen | xlpower | Sonstige Helis | 16 | 01.05.2020 21:37 |
Soxos Strike 7 | xlpower | Sonstige Helis | 1 | 06.02.2020 19:02 |
Soxos Strike 7 | xlpower | Sonstige Helis | 2 | 24.12.2019 22:45 |
Soxos Strike 7 | Thomas-H | Sonstige Helis | 102 | 16.10.2019 12:44 |
