Alt 18.03.2022, 19:37   #41
Keven S
Helicoach/MTTEC
Benutzerbild von Keven S
Danke erhalten: 2.856
Standard AW: Xl power
Der Dom wurde sehr stabil ausgeführt und Dom sowie Grundplatte sind aus 7075er Alu gefertigt.
Alt 18.03.2022, 19:49   #42
bronti
Benutzerbild von bronti
Danke erhalten: 3.420
und bei Std Servos hast ne 3 fache Lagerung
Heli87 (18.03.2022)
Alt 31.03.2022, 20:47   #43
bronti
XLPower Nimbus 550 Update:
Sadly, COVID-19 has had a surge in China in the last couple of weeks, and multiple cities and provinces have been locked down completely. Our factories at XLPower have been affected by this, and now Jiangsu province which XLPower is based in is one of those that is in lockdown. As of now we are completely unable to ship any parts or kits. UPS has cancelled and returned our last shipments. Many factories have ceased operations completely because they are unable to source the raw materials for production.
It is an unfortunate case of bad timing with the Nimbus kits and parts. We are hoping that within 7-10 days things will return to normal, but unfortunately we have no way of knowing for sure. We will keep you updated as we are able to, and greatly apologize to those who are anxiously awaiting their Nimbus 550.
Alt 23.04.2022, 21:26   #44
goone75
Danke erhalten: 1.092
Für diejenigen, die auf den Nimbus warten, mal ein neues Video zum Überbrücken der Zeit (keine Sorge, der Link funktioniert auch ohne Account):
https://www.facebook.com/NickMaxwell...0483751099255/
AndreasF. (23.04.2022)
Alt 24.04.2022, 00:45   #45
bronti
What's up all? Just a heads up, I'll be doing a livestream marathon build with the XLPower Nimbus 550 this coming Sunday, starting at 11:00AM CST on YouTube.
It'll be a complete build from unboxing to setup, and won't stop until I get there no matter how long it takes (unless something dramatic changes that). We'll have chat, Q&A, and just talk about whatever during the process of the build.
I'll also be demoing a couple of upgrades I have for the Nimbus 550 which will be available at KC3D shortly after the stream is over. I look forward to seeing you there!
#XLPOWER #Nimbus550
BladeScraper - YouTube
Alt 24.04.2022, 18:06   #46
bronti
Bau beginnt
Simon81 (24.04.2022)
Alt 08.05.2022, 10:09   #47
Smart Scaler
Danke erhalten: 35
Moin in die Runde,
hat schon wer Erfahrungen mit dem weichen Landegestell gemacht?
Ich bin noch unsicher beim Helifliegen, und setze vielleicht auch nicht immer ganz so sanft auf beim Landen. Mir ist jetzt schon 2 mal das Kunstoff Landegestell gebrochen.
Bisher ist zum Glück noch nichts weiter kaputt gegangen…
Klar soll es dämpfen bei härterem Aufsetzen, aber das da gleich was bricht finde ich nicht so doll.
Bei meinem alten Align 500 hatte ich mir ein Landegestell vom Compass 6 HV drunter gemacht das war sehr robust… nun müsste man mal gucken ob alternativ was anderes passt.
XL Power 520 , Dibolo 700 UL 6S
Smart Scaler ist offline   Mit Zitat antworten Zitiere markierten Text nach oben
Alt 08.05.2022, 13:30   #48
Keven S
Helicoach/MTTEC
Der Nimbus um den es hier im Thread geht hat ein anderes Landegestell als dein XLPower 520. Der Titel vom Thread hier ist leider etwas verwirrend
Damit es bricht muss der Schlag schon sehr kräftig sein. Wenn man größere Landegestelle von größeren Helis montiert, hat man eben immer das Risiko, dass das Chassis was abbekommt weil die Kraft dann hier voll eingeleitet wird wenn es eigentlich schon zuviel ist.
Alt 08.05.2022, 15:31   #49
Danke erhalten: 2.525
Wenn das Landegestell unter dem doppelten Heli Gewicht nicht bricht, liegt das Problem beim Piloten.
Das ist ja kein Rammbügel.
Alt 08.05.2022, 18:50   #50
michaMEG
Benutzerbild von michaMEG
Danke erhalten: 791
Reden AW: Xl power
Wäre ja auch mal eine Idee, so eine Art Karate mit dem Heli.
Mit dem Ladegestell Backsteine zerschlagen.
Oder ein gedämpftes Landegestell, mit richtigen Öldruckdämpfern.
Grüße, Micha
Zurück zu: Sonstige Helis
Sprit von Morganfuel: High Power vs. Cool Power Kurt T. Verbrenner 0 14.07.2008 12:56
Meinungen zum power optimate duo power 8S EQ-BID von Robbe Apfelz Akku und Ladetechnik 1 16.06.2008 00:11
2 x 3s 2200 mAh Lipo an Robbe Power Peak Compact Duo Power 6S EQ laden, geht das? -JPB- Akku und Ladetechnik 1 04.04.2008 19:50
Robbe Power Peak Duo Power Verwirrung andree Akku und Ladetechnik 2 20.11.2007 15:35
Power Peak Fun Duo-Power Dani2809 Akku und Ladetechnik 1 12.04.2007 00:01
Alle Zeitangaben in WEZ +2. Es ist jetzt 19:42 Uhr.
