Alt 11.04.2020, 09:06   #1
bronti
Benutzerbild von bronti
Danke erhalten: 2.368
Standard Goblin kraken 3 blades
The all new Kraken 3-blades kit
YouTube
Weight (no battery/fuel)
4100 g
• Light canopy, boom, low frames as for SG741
• New graphic scheme, very aggressive, obtained with a new process which adds so many details
• New main and tail rotor obtained as a mix between old HUB and new blade grip, used on Kraken
• New blades 690 mm produced with a new process that optimizes the final weight.
• Power train full enclosed in aluminum case.
• Independent belt shafts for the transmission and the tail.
• Ultra-light Tail case with quick tail fin replacement.
• Full body and boom design with integrated frames.
• Boom detachment system for improved crash durability.
Goblin Kraken introduce again many original solutions never saw in RC Heli world…
Kit Includes:
• Motor pulley 21T (other pulley sizes available)
• 2 sets battery tray with strap
• New SAB blades and tail blades ( 690 3 TBS + 115 3 TBS )
MAIN FEATURES:
TRANMISSION MODULE
• Power train support 3 shafts: Main shaft to the rotor, shaft to the motor, shaft to the tail.
• One-way system inside the Module
• Reliable, suitable for transmitting any power, it does not require maintenance.
• Sturdy in case of crash. It is possible to replace the main shaft by removing a single screw.
• The transmission module is supplied assembled and verified, ready to be used.
FEATURES
• The blade grips are made from 7075 T6 Aluminum and the blade grip arms are made from 6061 T6 Aluminum. In a crash you can bend the arm, but you will never damage the blade grip. Using 1x M4 screw makes it very easy to replace just the arm.
• Independent belt shafts for the motor transmission and the tail.
• Ultra-light tail case with quick tail fin replacement, 3 mm full carbon side plate, 23 grams lighter than the Thunder tail case. Very simple, strong, reliable & durable
• Kraken ESC support composite tray with sacrificial plastic insert. The edges are covered in rubber for protection...ESC wires are happy:-)
• Wire Support for super east wiring.
• Battery tray.
• Serial Number.
• Goblin Kraken High-tech composite carbon and airex sandwich.
GOBLIN KRAKEN 3 BLADES | Goblin Helicopters
vom Scheme her gefällt er mir besser wie der Edeka wäre das rot noch weg wäre es Perfekt!
Der Preis ist ok für den 3 Blatt 1199€
Release 30.04.20
Geändert von bronti (11.04.2020 um 09:10 Uhr)
Folgende 2 Benutzer sagen Danke zu bronti für den nützlichen Beitrag:
diabolotin (11.04.2020), Polten Sepp (11.04.2020)
Alt 11.04.2020, 09:20   #2
Danke erhalten: 1.274
Standard AW: Goblin kraken 3 blades
Die einzige echte Neuentwicklung ist die Lackierung.
Alt 11.04.2020, 09:24   #3
Polten Sepp
Benutzerbild von Polten Sepp
Danke erhalten: 1.421
Drei Blätter stehen dem Kraken gut!
Folgende 2 Benutzer sagen Danke zu Polten Sepp für den nützlichen Beitrag:
Carlo Scheerder (11.04.2020), Ulli600 (11.04.2020)
Alt 11.04.2020, 09:50   #4
Heko82
Benutzerbild von Heko82
Danke erhalten: 176
Flugort: Villach / Kärnten
Eines muss man SAB echt lassen, die haben die beste Verkaufsmasche.
Weil die geilste Lackierung ist wieder einmal der 3-Blatt was fast keiner fliegt
Das gleiche war beim Goblin 700 Havok da musste ich auch das Design zum 700 Sport zusätzlich dazu kaufen
Aber wie heißt es so schön „Egal!!“
Thats Hobby
Sieht jedenfalls geil aus, für mich der schönste bis jetzt.
Vbar Touch/ Mikado Logo 690SX/ Mikado Logo 550SX
Heko82 ist offline   Mit Zitat antworten Zitiere markierten Text nach oben
Folgender Benutzer sagt Danke zu Heko82 für den nützlichen Beitrag:
Alt 11.04.2020, 10:23   #5
Thoemse
Benutzerbild von Thoemse
Danke erhalten: 385
Bin wohl in der Minderheit aber ich finde alle neuen Goblins grottenhässlich. Das hat mit dem Havok Design angefangen und wurde nicht mehr besser.
T-Rex 700X (Speedrumpf), Tarot 550, Bell 222 (600), Hughes 500E (700 und 450), Devil 380
Alt 11.04.2020, 10:46   #6
Michael Hochsteiner
Benutzerbild von Michael Hochsteiner
Danke erhalten: 848
Das Design hat schon was, aber mit einem 3-Blatt Kraken hätte ich jetzt nicht wirklich gerechnet. Ist die Nachfrage an 3-Blatt-Rotorköpfen noch so groß ? Allgemein liest und hört man eigentlich nur noch wenig davon. Na ja, ich brauche es halt nicht.
..ich wünsche euch schöne Ostern, wenn man so sagen kann.
L.G.M
Klug zu fragen, ist schwieriger, als klug zu antworten.
Michael Hochsteiner ist offline   Mit Zitat antworten Zitiere markierten Text nach oben
Alt 11.04.2020, 10:49   #7
Catnova
Benutzerbild von Catnova
Danke erhalten: 1.786
Wenn der Kopf keine Neuentwicklung ist, kann man so vielleicht mit einem Griff ins Regal noch ein zwei Kunden fangen.
Axel
Alt 11.04.2020, 10:50   #8
bronti
Daumen hoch AW: Goblin kraken 3 blades
sei froh sparst Geld!
Der Sport ist mein NO1
Dateityp: jpg heli1.jpg (142,0 KB, 179x aufgerufen)
Alt 11.04.2020, 10:50   #9
Moses
Benutzerbild von Moses
Danke erhalten: 386
Flugort: MBG Radfeld, Tirol
Für 3-Blatt SAB bin ich immer empfänglich, aber in dem Fall muss ich ehrlich sagen, die Lackierung ist eine Katastrophe
Grüße Michael
Bell 412 Canada Rescue, Bell 206 Jet Ranger, Goblin Urukay Competition
Alt 11.04.2020, 13:24   #10
lottacustoms
Benutzerbild von lottacustoms
Danke erhalten: 635
Flugort: Bei Tübingen
hab ich auch schon ewig als Konstruktion und Prototypen auf dem Tisch liegen.
Natürlich auch das passende Heck.
Aber der Trend war meiner Meinung nur kurz und wird auch nimmer kommen.
Da hilft die beste Konstruktion und auch das hübscheste Design der Haube nix.
Nur meine Meinung
Marco
Dateityp: jpeg D63C6030-15AB-4D56-A228-F1B0FDAD22E0.jpeg (366,9 KB, 412x aufgerufen)
Zurück zu: Newsforum
[Goblin allg.] Goblin Kraken Polten Sepp SAB 1702 04.08.2020 17:48
Motor für den Goblin Kraken cayennes1 Elektro 10 27.07.2019 17:56
Goblin Kraken Unboxing bronti Bilder und Videos 0 19.04.2019 10:51
Goblin Kraken Janis Newsforum 278 24.03.2019 13:19
[Goblin Speed] Goblin Speed/700 - 711 DH Blades mit 115 Rail Blades möglich? jsifly SAB 3 10.04.2015 12:47
Alle Zeitangaben in WEZ +2. Es ist jetzt 20:30 Uhr.
