Alt 06.06.2016, 21:34   #1
freakystylez
Benutzerbild von freakystylez
Danke erhalten: 3.883
Standard MSH Brain Firmware Update inkl. Rescue - Probleme, Fragen & Erfahrungen
der Übersichtlichkeit halber wäre es cool, wenn wir hier weiter machen würden, damit es im großen allgemeinen MSH Brain Fred nicht unter geht!!!
Hier die Release notes:
Zitat von KU-HELI7 Beitrag anzeigen
2.0.000 (Firmware 2.0.000)
- In some case, when Spektrum satellites are binded by software, setup is defaulted: Fixed
- Added in the “Connections” panel of the Wizard, also schematics for uBrain2 miniBrain2 Brain2, Brain2BT, Brain2HD, Brain2HDBT
- Added in “Demo Mode” the uBrain2 miniBrain2 Brain2, Brain2BT, Brain2HD, Brain2HDBT in the unit selection
- Auto level algorithm completely revised and now is self-configured and auto correct itself
- Removed “Set Level” button from “Unit Orientation” panel of the wizard (now is automatic)
- Removed “Aileron angle for hovering” and “Elevator angle for hovering” cursors (now are automatic)
- Removed “Auto Level” checkboxes from “Flying Style Setup” panel of the Wizard
- Added in the Wizard the new panel “Rescue Mode Setup”
- Added the ability to activate the Auto Level with positive pitch increment (Auto Level or Full Rescue)
- Added the ability to activate the Auto Level with or without positive pitch increment also with another unused radio channel
- Added “Use Rescue” checkbox and “Pitch Rescue increment” and “Time Rescue increment” cursors in Advanced -> Setup n° -> Gov. & Level view
- Added the new panel “Rescue” in Advanced -> Common for dedicated radio channel
- Added “Reversed Pitch ” checkbox for model in which the maximum pitch is obtained when the swashplate is all down
- Added a bec test during swashplate and tail movements at end of init. If voltage drop more than 12% an event is recorded (only for unit 2)
- Added the ability to write and edit the instructions in any other language other than those already provided and share the language file with other users
- Removed the “Reset Flight counters” from File menu
- Removed the “Main Counters” from Advanced menu
- Added a new Timer menu with the Main Counters and 4 new timers for components maintenances each with a “partial reset” button
- Added Logs Setup views (only for “2” units)
- Added Real time logs view (only for “2” units)
- Added Recorded Logs view (only for “2” units)
- Added Vibration real time view (and recorded only for “2” units)
- Added Events view (only for “2” units)
- Now Setup are in the same page so it is easier to compare
- When you enter a numeric value the box background become yellow until you finish and push “Tab” key
- In panel 2 “Servo Setup” of the wizard, added a Servo chart list (updated with every new release)
- Corrections and fixes to some instructions
- Small bug fixes and optimization of code
Setting changes to do from previous version:
- If you have reversed the pitch in the transmitter, correct it and use "Revesed Pitch " checkbox in panel 6 "Swashplate Type selection" of the wizard, when using reversed swashplate pitch (swashplate down positive pitch )
- Ensure that in the panel 9 "Unit Orientation" of the wizard, the corresponding icon to the actual unit position is active.
Geändert von freakystylez (06.06.2016 um 21:36 Uhr)
Folgende 11 Benutzer sagen Danke zu freakystylez für den nützlichen Beitrag:
75ms (06.06.2016), Bibo1983 (06.06.2016), corsair107 (07.06.2016), DerMax1976 (06.06.2016), Diablol (06.06.2016), Fetzi (07.06.2016), ManuelW (23.08.2016), Rotzlappe (07.06.2016), rrunner (07.06.2016), slevin (06.06.2016), ueber30 (07.06.2016)
Alt 06.06.2016, 22:09   #2
75ms
Benutzerbild von 75ms
Danke erhalten: 51
Flugort: Zwischen Ulm und Stuttgart
Standard AW: MSH Brain Firmware Update inkl. Rescue - Probleme, Fragen & Erfahrungen
Ich werde mit dem Update noch ein paar Tage warten, bis die ersten Rückmeldungen da sind
Gaui X4 V2, Gaui X5, 700 Dfc, G700C
75ms ist offline   Mit Zitat antworten Zitiere markierten Text nach oben
Alt 06.06.2016, 22:10   #3
eleven.ch
Benutzerbild von eleven.ch
Danke erhalten: 323
Flugort: Bern
Jup, mache ich auch so.
gruess simon
blade 130x @ spin 8000
compass warp 360 / brain
goblin 500 / brain
eleven.ch ist offline   Mit Zitat antworten Zitiere markierten Text nach oben
Alt 06.06.2016, 22:11   #4
Bibo1983
Benutzerbild von Bibo1983
Danke erhalten: 10
Ich auch [emoji55]
Goblin 500 mit BRAIN, YGE120, Savox-Servos und Quantum 4120
Blade 200 SR X
Bibo1983 ist offline   Mit Zitat antworten Zitiere markierten Text nach oben
Alt 06.06.2016, 22:14   #5
47110815
Benutzerbild von 47110815
Danke erhalten: 629
Flugort: Offenbach am Main
Ich werde auch noch warten.
Alt 06.06.2016, 22:17   #6
animatic
Ich habe es aufgespielt. Mal schauen wann das Wetter mitspielt.
Alt 06.06.2016, 22:19   #7
Diablol
Benutzerbild von Diablol
Danke erhalten: 1.884
Flugort: Aalen & Iffezheim
Du kannst uns doch jetzt nicht mit so nem Thread shocken/enttäuschen....
Ich hab mich schon im Nachtfug gesehen...
Edit: OH jetzt seh ichs erst... omg noch schlimmer wie soll ich jetzt schlafen..
Alt 06.06.2016, 23:10   #8
animatic
Schon etwas bekannt wann die passende Android App kommt bzw. Das Update?
Alt 06.06.2016, 23:13   #9
Letsgo
Benutzerbild von Letsgo
Danke erhalten: 361
wie jetzt Leute??
.. einer muss es ja probieren
ich weiss nicht ob ich warten kann,.. der oxy muss aber am Mittwoch in Italien am Strand flugbereit sein
Letsgo ist offline   Mit Zitat antworten Zitiere markierten Text nach oben
Alt 06.06.2016, 23:57   #10
KU-HELI7
Danke erhalten: 756
Sollte ein paar Stunden nach der neuen Firmware kommen.
Gruß Helmut
Alle Zeitangaben in WEZ +2. Es ist jetzt 01:37 Uhr.
