Acrobat SE
  • simon109
    simon109
    Acrobat SE
    Hello,
    I will be getting my Acrobat soon and i am using the 15/12 which lipo's do you use/recommend ?
    I have seen a picture on here with someone using Flightpower 5s2p is this a direct fit ?
    Sorry it is English
    Regards
    Simon.
  • Wilfried
    • 29.07.2003
    • 949
    • Wilfried
    • MFC Bremthal
    Acrobat SE
    Hello Simon
    Out of my last experience, I would suggest the Kokam 3200 in the configuration
    5S1P . / 3 cells - 2 cells in a row => fits into the akku - holder of the Acrobat and gives no problems with the centre of gravity.
    Max. 60 A and with the Voltage of approx. 16,5 V under load a nice performance.
    Flight - time : 6 .... 11 minutes according to your flight-style.
    You have to be carefull with the setting of the controller.
    I was told by Stefan Plöchinger to start with a speed-setting of only 48 % unsing the Jazz to get a rotor - speed of about 2000 1/min ( with the 14 teeth pinion ).
    A pinon of 13 teeth would be better, but is ( as far as i know ) not available at this moment.
    best regards
    http://www.mfc-bremthal.de/
    • Kraeuterbutter
      Kraeuterbutter
      Acrobat SE
      something Christian Samuelis has posted at rcgroups (he is the other guy at Stefan Plöchingers homepage flying the AcrobatSE):
      The best batteries will be 1p Kokam 3200h or Pro Lites 2p/3p. The Kokam 1p will have slightly more pressure than the 2p Pro Lites (@15°C). When you go to 35°C this advantage will have almost vanished. The TP 2p has the advantage, that its lighter. I Like the 5s2p TP Setup for 9 minutes of moderate hard 3d while the kokam 5s Setup is for 6 minutes hardest 3d. When you want to use 4s, I would prefer TP Pro Lites 4s3p. This should give good performance for at least 11 minutes.
      If you already have a 5s2p Pro lite pack at least try to fit the battery somehow for a test flight. The Performance ist amazing, much better that at last years 3dm. With 5s2p pro lites my normal Flying time is around 9 Minutes. With the 4s3p you will get 11 minutes (both hard 3D). The Fun factor is worth to loose 2 minutes ;-)
      • simon109
        simon109
        Acrobat SE
        Hello,
        Thankyou for your rreplies. I have found the picture of the FP 5s2p http://www.rc-helicopter.org/forum/index.p...obat%20se&st=15 I was wondering which motor he is using and his flight times ?
        I think the TP 4s3p is going to be the one I use though.
        Regards
        Simon.
