Base loaded Antenna
  • simon109
    simon109
    Base loaded Antenna
    Hello,
    Does anyone use a base loaded antenna on their Acrobat SE ?
    Regards
    Simon.
  • Markus Gann
    • 13.04.2004
    • 360
    • Reutlingen und Umgebung
    Re: Base loaded Antenna
    Hi Simon,
    there were some interesting discussions about that antenna. I cannot remember if it was used with an Acrobat SE, though. You may use the search function ("Suche") to search for information (e.g. try "base" as search word).
    good luck
    Acrobat SE, Agusta A109 (Century Swift 550), Bell 212 (JR Parkmite)
    • Markus Gann
      • 13.04.2004
      • 360
      Well, I am just realizing that you possibly will not be able to understand the discussions . I will try to find some relevant threads and give you a short summary in English.
      bye
      • Markus Gann
        • 13.04.2004
        • 360
        Simon, you can ask "Lattinger". He uses such an antenna in his Acrobat SE: http://www.rc-heli.de/board/index.php?topic=49934.15. Just send him a private message and ask him.
        • simon109
          simon109
          Thankyou Markus,
          I will Google the link you gave me Their language translations are ok, I can normally make most of it out.
          Simon.
          • Markus Gann
            • 13.04.2004
            • 360
            OK.
            But whatever you learn about base load antennae: if you build it in your model make sure to check the range before you fly!
