ring nt frage
  • ferry
    ferry
    ring nt frage
    hello, i am rebuilding my nt rotorhead after ein absturtz :[
    can somebody tell me , the nt ring what goes under the swash , how high in mm is it ?
    i dont have it , and i need the measure for adjusting the connecting rods
    thanks in advantage , ferry
  • DirkS
    3Digi
    • 13.07.2006
    • 1028
    • Dirk
    • Unna/Fröndenberg
    AW: ring nt frage
    Hi Ferry,
    the ring is 18,5mm high. Inner diameter is 36mm.
    Dirk
    3Digi Flybarless
    • ferry
      ferry
      AW: ring nt frage
      ah , danke dirk fur die snelle reply !!
      gruss ferry
      • ferry
        ferry
        AW: ring nt frage
        guys , im a bit confused.
        is it right to put a 18.5 mm ring under the taumel , and then make all the links so , that the blades are 0 degrees and the mfs /paddelstange , is in the middel of the slot ?
        if so , please tell me .
        gruss ferry
        • ferry
          ferry
          AW: ring nt frage
          ok , something is not wright with the 18.5mm ring .
          i made a ring , but 18.5 mm is too high for 0 degrees pitch , if i give negative pitch it can only go 2 more mm untill the taumel hits the headblock.
          can someone give me measurements of the links on the head ?
          regards ferry
          • Paulh
            • 26.02.2007
            • 49
            AW: ring nt frage
            ik heb een PB gestuurd.
            • DirkS
              3Digi
              • 13.07.2006
              • 1028
              • Dirk
              • Unna/Fröndenberg
              AW: ring nt frage
              Hi Ferry,
              you can download the manual for the NT here.
              On page 14 you will find the length for the pushrods.
              Dirk
              3Digi Flybarless
              • ferry
                ferry
                AW: ring nt frage
                i got it .
                it is the same as the mp ring
                only difference is , that the nt ring is higher , but it is wider and therefore rests on the outer seat of the swash.
                while the mp ring is thinner , but it rests on the inner ring .
                it works out to be the same , you can use eiteher ring .
                i got confused becouse i saw on the henseleit site , that the partnumber for the nt ring and mp ring are the same .
                it works beautifully now , i lopve the nt !!
                thanks people!
