Raptor30 Version??
  • boysen
    boysen
    Raptor30 Version??
    Hi!
    Woran erkenne ich konkret und schnell und einfach, ob es sich um einen Rappi30 V1 oder V2 handelt*
    bitte um Tips
    Tom
  • Maik Otto
    Maik Otto
    Raptor30 Version??
    Hi Tom ,
    ob dir das wirklich hilft weiß ich nicht aber das sind die aktuellen
    änderungen zum V1
    Old Part #
    New Part # Description Changes
    PV0034 PV0363 Fuel tank increased to 370cc
    PV0023 PV0358 Clutch bell bigger size
    PV0024 PV0359 Clutch bigger size
    PV0090 PV0368 Clutch liner bigger size
    PV0025 PV0360 Starting shaft higher load capacity
    PV0026 PV0361 Starter coupling higher load capacity
    AK0043 PV0367 Pinion gear higher load capacity
    PV0094 PV0203 Bearings design change
    PV0012 PV0012 Collective pitch control arms increased rigidity
    PV0013 PV0013 Elevator control arm increased rigidity
    PV0010 PV0357 Swashplate increased precision & rigidity
    PV0001 PV0353 Main blade grips design change
    PV0047 PV0365 Thrust bearings design change
    PV0006 PV0372 Collar, thrust bearings design change
    PV0050 PV0374 Bearings, spindle design change
    PV0007 PV0355 Feathering spindle increased load capacity
    PV0009 PV0356 Rubber dampers increased load capacity
    PV0003 PV0354 Main rotor hub increased load capacity
    PV0005 PV0005 Flybar control rod improved ball end structure
    PV0002 PV0002 Flybar control arm 0.8mm longer
    AK0004 AK0004 Flybar seesaw hub anodized
    PV0011 PV0011 Elev. control arm linkage improved ball end structure
    PV0038 PV0038 Vertical fin added rip and length
    PV0019 PV0019 Hub, oneway clutch hub anodized
    PV0042 PV0328 Tail boom support new design
    PV0031 PV0151 Tail rotor hub R60 hub used
    PV0028 PV0148 Tail rotor grips R60 grips used
    PV0049 PV0200 Bearings R60 bearings used
    PV0066 PV0370 Body new style
    PV0065 PV0369 Wind shield new style
    PV0061 PV0375 Body retaining post new style
    PV0055 PV0366 Decal new style
    Ps: an der Haubenform , den größerenj Blatthaltern so wie dem größeren Tank
    • martin_fuerst
      • 12.06.2001
      • 4094
      Raptor30 Version??
      Hallo Tom,
      Ganz schnell (ohne eine Vergleichsmöglichkeit zu brauchen)
      Rotorblatt aus dem Blatthalter - einen Blick auf die Befestigung
      der Blatthalter an der Blattlagerwelle.
      Ist dort eine Stopmutter - dann V1 (zumindest der Rotorkopf)
      Ist dort eine Inbusschraube (dann V2)
      Blick auf den Motor:
      Wenn 36 obensteht, dann V1
      Wenn 39, dann....
      Da der V1 einen kleineren Tank hat (aber die gleichen Kufen)
      sind beim V2 (wo das Chassis breiter ist - für den größeren Tank)
      die L - Winkeln (dort wo die Kufenbügel verschraubt werden)
      anders.
      D.h. beim V1 sind die L nach aussen, beim V2 gehen sie nach innen
      (unter den Tank) - nur hinten.
      Alles unklar
      Es gibt noch einige Merkmale
      Martin
      Wettbewerbsklasse J4F​
      • Thoddy
        Thoddy
        Raptor30 Version??
        warum eine Frage zu einem Thunder Tiger-Heli im Schlüter Forum ? Vielleicht etwas falsch gelaufen ?
        • martin_fuerst
          • 12.06.2001
          • 4094
          Raptor30 Version??
          Möglicherweise, weil sich Tom geirrt hat
          oder Robbe ihn im Progamm hatte
          P.S:
          Ein Admin oder Supermod kann es ja bei Gelegenheit verschieben (ich nicht)
          Grüsse
          Martin
          • Thoddy
            Thoddy
            Raptor30 Version??
            Is' ja auch nich' schlimm Nur 'ne Frage :rolleyes:
