Oxy advisory #1
  • eg183100
    Lynx
    Teampilot
    • 07.02.2009
    • 442
    • Erik
    • Mönchengladbach
    Oxy advisory #1
    Our Oxy3 has been selling beyond expectation. We are excited to see so many at local flying fields!
    We have discovered a small issue with some Oxy3 47mm tail blades. Some sets of blades included in our kits were not balanced before leaving the factory.
    Because we wish to support our customers, we will be sending all registered owners a new set of 47mm tail blades, free of charge. These new blades are also further optimized in design.
    Additionally, we have updated the standard tail ratio by changing the stock tail pulley from 14T to 15T. This slightly slows down the tail rotor, which is appropriate if you are running head speeds greater than 4000rpm. We will include this 15T pulley when we send registered pilots the tail blades.
    We advise you to change the tail blades immediately and dispose of the old ones. However, the tail pulley only needs to be changed if you are running high head speeds.
    Please register your Oxy3 Register OXY Helicopter to receive your new tail blades and tail pulley.
    Good luck with your flying
    The team at Oxy Helicopters
    Lynxheli / OxyHeli Team Pilot
  • Klaus O.
    • 03.12.2007
    • 22477
    AW: Oxy advisory #1
    Gehts auch in Deutsch.
    Gruß Klaus
    • PMO
      PMO
      • 04.07.2009
      • 2252
      • paul
      AW: Oxy advisory #1
      Die im set enthaltetnen Heckblätter sind nicht gewuchtet..blablabla
      Die heckübersetztung wurde geändert damit leute die über 4000 am kopf fliegen keinen stress mim heck bekommen...bla bla
      Du kannst Dich im link anmelden und bekommst toll gewuchteten 47mm Blätter und auch noch das 15 Rad fürs heck..
      • tc1975
        • 18.08.2008
        • 6776
        • MFG Tangstedt
        AW: Oxy advisory #1
        ...ist doch ein toller support wie ich finde!!!
        RAW 700 / Nitro - @VBar Touch
        • DerMitDenZweiLinkenHänden
          • 09.12.2004
          • 12089
          • Kurt
          • Hinterbrühl/Wien
          AW: Oxy advisory #1
          Habe ich den Ironie-Tag irgendwo übersehen?
          Kurt
          • phiphi
            • 01.12.2009
            • 3974
            • Philipp
            • Beromünster ( LU ) CH
            AW: Oxy advisory #1
            Warum Ironie
            Ich finde es lobenswert, das ein Hersteller sogar nicht perfekt gewuchtete Heckblätter "zurückruft" - und das "Upgrade" mit der Heckübersetzung gleich mitliefert. Das müsste man bei vielen anderen Herstellern erstmal selber in Erfahrung bringen und dann auch noch selber bezahlen...
            Grx Phi
            Ich wäre lieber am fliegen...
