Setup Raptor E550 - GT5.2 - Futaba 14SG
  • time2party
    time2party
    Sorry for the writing in English bat i am from Belgium not so good in writhing in German language.
    I am trying to setup this new heli and gyro.
    It-s a TT Raptor E550 with 3 blades and the Ace GT5.2.
    The TX is Futaba 14SG and RX Futaba 7008SB, so I connect the Gyro with one cable to the Sbus on the RX.
    All movement of the head are ok bat have some trouble to setup the TX and the Gyro.
    On the GT5.2 you have on its display right bottom to number, for what I read is this the gyro gain and have to set on 100.
    If I go in the 14SG to Gyro menu and change the first gyro setting then the upper number on the GT5.2 moves and I can set it to 100.
    The second number do not move and stays at 50. How to change?
    Theses number are white bat the top number that I can change I can change to 100 black on white or white on black.
    What do this mean?
    Second, does anyone has a correct setting for the GT5.2 (settings in the GT5.2) to start with?
    Thanks, Peter.
  • Thomas Geisel
    • 04.04.2014
    • 870
    AW: Setup Raptor E550 - GT5.2 - Futaba 14SG
    Sorry , my english is bad too. But I have a english manual where the setup of these numbers are discribed. I can scan the part of the manual and mail it if you give me your mailadress. There are different ways to set them up . I used the fixed setup of these numbers and set both to 100%.
    In the manual its called " funktion asignment "
    Logo 690, Goblin 570 Sport, Goblin BT 700 Sport,Goblin 580 Kraken
    • time2party
      time2party
      i have sent you a PM.
      i try to set this numbers to 100% on the TX bat cant find how to do it.
      just the first one i can change?
      • Thomas Geisel
        • 04.04.2014
        • 870
        The problem is , that there are only very few people using that fbl . So it is difficult to get help
        • Robert Englmaier
          ( Roben155 )
          • 02.11.2010
          • 8957
          A Setup-Tutorial from Simone is online on Youtube, however in German!
          E700 Baubericht #5 (deutsch) GT-5.2 Setup Teil 1 - YouTube
          Grüsse Robert
          • Techmaster
            • 28.03.2014
            • 4153
            • Alex
            • Gifhorn
            Die Spracherübersetzungsapp könnte sie dann auf Englisch übersetzen, man könnte das Handy an den Lautsprecher halten...
            Aber die Thunder-Tiger GT5 2. Anleitung dürfte man aber auch bestimmt leicht in englisch finden.
            • time2party
              time2party
              hi,
              i have seen this video bat is not working on my futaba 14sg.
              the first number i can change, the second one not.
              also you have the number on white or on black backgroud?
              thanks for answers.
              • FirstLady
                SAB
                Teampilot
                • 21.05.2008
                • 1006
                • Simone
                • 52391 Vettweiß
                GT5 Video in english
                [YOUTUBE]TnDTlRP719I[/YOUTUBE]
                [YOUTUBE]PXZGIli7ZnM[/YOUTUBE]
                [FONT="Arial Black"]www.firstlady1985.jimdo.com[/FONT]
                • time2party
                  time2party
                  Hi FirstLady,
                  I have seen your video before on the net and try it out bat on my Futaba 14SG I don-t get I well.
                  Like I say only the first number I can change and then I have two options.
                  On with the number on a white background or on a black background.
                  I do not know what this means?
                  Thanks.
                  • Thomas Geisel
                    • 04.04.2014
                    • 870
                    There are a lot of threads on helifreak about the GT5.2
                    Thunder Tiger GT5 FBL System - HeliFreak
                    maybe you can find some help there.
                    But on the other hand , you don´t need to change the numbers of the gain for normal flying .
                    with 50 on both the heli will fly well .
                    • FirstLady
                      SAB
                      Teampilot
                      • 21.05.2008
                      • 1006
                      • Simone
                      • 52391 Vettweiß
                      I am sorry but I dont have any experience about futaba Radios. also ist now over 2 years that i used a gt-5 so i am not Aware about the newest Features / Software updates that they put into it.
                      The Videos I did with the Graupner Radio are the only help I can provide now
                      • time2party
                        time2party
                        • Thomas Geisel
                          • 04.04.2014
                          • 870
                          Sorry to hear that. Was this your First heli? Or the first you build and setup?
                          • time2party
                            time2party
                            NO, not the first build en not the first setup.
                            BAT the first Raptor 3 blades and the first GT5.2 :-(
                            And the last i think :-)
