supplied capacity
  • Codon2006
    Codon2006
    supplied capacity
    Das B6 hat eine Anzeige, die als supplied oder charged capacity bezeichnet wird. Was ist damit gemeint und welche Info bekomme ich aus dieser Zahl? Danke!
  • Codon2006
    Codon2006
    AW: supplied capacity
    ...hab glaub ich gefunden:
    As others have said, it's the capacity placed back into the battery during a charge. It isn't a percentage because the charger doesn't know anything about the battery - it has no way of knowing how far discharged it was, or what the total capacity ought to be, or any of that. All the charger knows is how many mAh have been placed back into the pack since you started the charge. As a result, if you stop the charge, the counter will reset.
    It starts at zero, because at the beginning the charger has not placed any power back into the battery. As time progresses, the amount will slowly rise. If you fully discharged the pack, the number at the end of the charge cycle will be very close to the capacity printed on your pack.
    • tasse
      • 12.09.2011
      • 6061
      • Tassilo
      Das iMax B6 meinst du?
