OS91 HZ Heim ? Lange Kurbelwelle?
  • ferry
    ferry
    hallo guys
    does anybody knows if graupner has allready come up with a heim version of the hz ? or maybe a 8mm crankshaft ?
    if not , does anybody know a way around that so a hz motor can be fit , becouse i think the sz/rz crankshaft will not fit the hz , right ?
    regards ferry
    Zuletzt geändert von Gast; 11.03.2009, 18:22.
  • Kev
    Kev
    AW: OS91 HZ Heim ? Lange Kurbelwelle?
    Hello,
    whether the HZ with an 8mm home crankshaft there I do not know, because it must necessarily be of HZ?
    The SX has until very Dato reinforced.
    Greeting
    Kevin
    • awhelisi
      GESPERRT
      wegen Betrugsverdacht
      • 18.09.2001
      • 3830
      • Arne
      Hi Freey.
      The only one you can buy is the OS 91 RZ HG.
      You can find it here. http://www.mhm-modellbau.de/part-G-2711.php
      Regards Arne
