in my opinion the swash should be level at all positions.
So if you level it at zero pitch it should be level in all positions. To trim the swash within the trim-card should be all to do.
Agree with Tom 100%, as far as I got the question...as this is not only the swash setup for FBL helis, but for all helis in any case. No need at all to set a swash another way, but always level.
Or do you mean that the problem is to get the swash level in all position, and you did not manage to do so? In this case I can only state that you should have a look at the mechanics of your heli, as the HeliCommand does not tilt the swash when only giving collective inputs.
I had a Vstabi before and in the software you can setup the swash level @ zero pitch, full positive pitch and full negative pitch, becouse no servo moves exactly the same way .You always have little differences in movement.
