Spirit 3.2.0
  • Till
    • 31.05.2001
    • 1939
    • Till
    Spirit 3.2.0
    New version 3.2.0 released!
    Brand new Quick Flashing Process:
    From now you can flash new firmwares more smoothly, faster and reliable.
    Firmware flashing can take just 7 seconds!
    Once flashed, new firmware will boot up instantly with no need for re-power.
    All settings are preserved as usually.
    New Flashing Procedure will take effect after 3.2.0 update. Then next updates will be much faster.
    Incorrect firmware flashing is not possible anymore.
    NOTE: Transition from older firmwares is the most important to complete properly.
    NOTE: Make sure that your computer can flash firmwares properly prior this upgrade. This is required only for this update, since old flashing method is still used (only first time).
    NOTE: We recommend for Mac OS X users to make this transition on a Windows or Linux computer due to known driver issues. After this update, updating with Mac will be perfectly safe.
    NOTE: If you want to downgrade to an older version, it is possible to obtain old compatible version upon request. Original old firmwares will not work.
    New easy Recovery mode:
    In case that firmware flashing was interrupted for whatever reason, Spirit unit will boot up in recovery mode automatically.
    You can finish the flashing once unit will start to blink with LED quickly.
    Enter Recovery Mode when Status LED is blinking quickly, select firmware and just press the Flash button.
    Futaba SBUS/SBUS2 enhancement:
    Each data frame is examined to match correct time synchronization.
    Additional protection from corrupted packets.
    Support for three SRXL2 satellites:
    From now Spirit 2, Spirit RS, Spirit Pro and µSpirit units can be interfaced with additional satellites.
    You can connect them at the satellite ports with SRXL2-satellite adapter.
    NOTE: We still recommend to use full size receiver + satellite receiver together.
    Improved Spektrum Integration:
    Entering and closing the Integration menu is now more intuitive.
    Only once menu is completely closed with sticks, you will see CLOSED label.
    During closing you will see CLOSING label.
    Improved detection of SPM4649T receiver:
    Receiver is now detected properly so that integration should work always well with all Spektrum radios.
    Spektrum DSM2/X protocol:
    Spektrum satellites are switched faster on signal loss.
    Temporal signal loss during satellite switch is only 100ms long.
    JETI telemetry tweak:
    S RPM parameter has RPM extension after value.
    This can be usefull for voice speech output.
    HobbyWing ESC telemetry:
    Temperature will corelate with ambient ESC temperature now.
    µSpirit - Rudder ESC motor:
    Motor will turn on immediately when Throttle function is assigned and Low RPM parameter is configured.
    New Anti-Gravity feature:
    This feature is modifying Collective Pitch steering to gain lighter feeling of the model.
    When model is skids down, bottom half of the pitch has not that impact. Model will not descend that quickly.
    In other words with 50% value you will obtain +12° but only -6° for negative side.
    This is especially useful for smaller helicopters of 250 class and smaller.
    This parameter is not changing Collective Pitch range. So you do not have to make any other adjustments.
    New parameter is located in the Expert Settings.
    GeoLink features and Rescue mode:
    From now Rescue Duration parameter will take effect with GeoLink features engaged.
    Spirit Settings - Messages:
    Spirit Settings software will let you know what is needed to do in unusual scenarios (Version Mismatch, Updating)
    Spirit Settings - Log Viewer:
    Fixed problem with a non standard Documents directory location.
    Logs should always open whenever Documents directory is located.
    Spirit Settings - In-Flight Vibration Analysis:
    Vibration Analysis can be selected for any Special Function.
    Previously only first 3 Special Function assignments allowed to see In-Flight option in the Analysis window.
    No need to change any parameter after update from version 3.1.
    WARNING: Make sure that your computer can flash firmwares properly prior this upgrade. This is required only for this update, since old flashing method is still used (only first time).
    WARNING: We recommend for Mac OS X users to make this transition on a Windows or Linux computer due to known driver issues. After this update, updating with Mac will be perfectly safe.
    NOTE: This update must be performed with Spirit Settings 3.2.0.
    Update for the Spirit units, Wifi-Link, JETI integration is available in our Download section.
    _________________
    Spirit System developer
  • parkplatzflieger
    • 18.03.2012
    • 8994
    AW: Spirit 3.2.0
    Ergibt es Sinn, für jede Unterversion der Spirit-FW einen neuen Thread zu starten?
    Torsten
    Voodoo 600, Logo 600SX
    Spektrum, Spirit, Heli X
    • Till
      • 31.05.2001
      • 1939
      • Till
      AW: Spirit 3.2.0
      Ja
