Aus GY502 wird GY601
  • xconsult
    • 12.05.2003
    • 852
    • Ã?sterreich
    Habe einen interessanten Eintrag in einer Futaba Newsgroup gefunden:
    .. Just press both Menu buttons while powering on the gyro. Among the endless
    parameters in the GY502 hidden menu you will find the FMod which is a
    standard function in the GY601 mode and the PlsW which lets you use
    an S9251 narrow pulse servo with the GY502. However, the gyro remains
    a GY502 until the extra components are added on the PCB and the gyro
    is "told" that it is a GY601. Then a "RESET" via the hidden menu
    loads all the configuration parameters for the GY601. After this the
    gyro will greet the user with *GY601* on the display and the menu
    will be a normal GY601 menu.
    Michael
  • Thilo
    Thilo
    However, the gyro remains`a GY502 until the extra components are added on the PCB and the gyro
    Hallo!
    Aber was ist mit diesem Satz? Welche Komponenten fehlen denn noch auf dem PCB (printed circuit board -> Platine)?
    Thilo
