Spektrum Empfänger mit neuen Funktionen
  • uknoke
    turbinen-sound.com
    Bauservice
    • 30.08.2006
    • 849
    • uwe
    Blinkende LEDs zeigen Niederspannung-Benachrichtigung
    QuickConnect Spannung Recovery-System für DSM2 Air Receiver
    Zitat:
    Flashing LEDs indicate low voltage alert
    QuickConnect allows most flyers to fly through common low-voltage situations caused by insufficient battery "headroom" - in many cases, without knowing a problem ever occurred. As a result, Spektrum engineers decided to program the system so that the receiver LEDs would flash, should the QuickConnect feature be triggered in flight. This can also be demonstrated on the bench, by toggling the airborne power.
    If your receiver is missing one or both of these features, first off, it's important to recognize that the vast majority of flyers using "normal" servos with "normal" properly charged batteries will be unaffected by low-voltage issues. The best fix, however, remains assuring adequate power supply to the airborne system with sufficient voltage headroom.
    Your flying success is of paramount importance to Spektrum as the leaders in spread spectrum technology, we're constantly moving the bar upward. Also, whenever you have questions regarding your Spektrum equipment.
    QuickConnect Voltage Recovery System for DSM2 Air receivers
    Performance modelers have known for some time that care must be taken to assure adequate power supplies for their airborne system. It-s true for all radio systems, but it-s doubly important when using high-performance servos, flying harder maneuvers, and trying to save weight with inadequate batteries and/or regulators.
    Spektrum systems are designed with an operating threshold of 3.5 volts, and lower voltages cause the system to shut down. When adequate power is regained (usually the drop is momentary), earlier Spektrum systems re-boot and rescan for two previous channels before control is restored - a process usually requiring two to five seconds.
    The new QuickConnect feature, however, eliminates the scanning delay and restores control almost instantly. We have been integrating this upgrade into receivers in a running change. Here-s how to identify if your receiver has QuickConnect:
    With the system operating normally, simply switch the airborne power off, then on. If your system shows virtually no delay in regaining control, your receiver includes the QuickConnect feature.
    MfG
    Uwe
  • Ovid
    Ovid
    AW: Spektrum Empfänger mit neuen Funktionen
    Wurde hier schon öfter besprochen. Gilt für Empfänger die nach Juli 2007 ausgeliefert wurden!
    • uknoke
      turbinen-sound.com
      Bauservice
      • 30.08.2006
      • 849
      • uwe
      Die Mitteilung von Spektrum ist vom 14.2.2008 und die Empfänger werden aktuell erst ausgeliefert.
      • Rusty
        • 19.10.2006
        • 131
        • Bernd
        • Ostfriesland
        steht in der anleitung der dx6i und bei horizonhobby das das ab 07/2007 mit quick connect geht....
        T-Rex 700E BeastX, Blade 130X
        Taranis X9D DM9, Akkumatik V1, iCharger 308, ISDT Q6Plus
        • Ovid
          Ovid
          Siehe auch hier:http://www.rc-heli.de/board/showthread.php?t=64087
