Heute erhalten:
http://publications.horizonhobby.com...21360/10762/0/ for
Spektrum DX6i transmitters due to a concern of potential issues with
stick potentiometers. Consumers were strongly advised to conduct a
test to see if symptoms of these potential issues were present.
After closely monitoring the situation, Horizon has determined that we
need to physically inspect all DX6i transmitters with date codes
containing 807E, 808E, 809E, 810E, 811E, 812E, and 901E, including
those ending in "US", "UK", or "DE". The date code will be found
inside the battery compartment.
If your DX6i has one of these date codes:
Stop using your transmitter.
Nehme an, dass von Horizon Europa entsprechende Informationen zur Abwicklung kommen werden oder das Procedere erfragt werden kann, sollte Ihr Sender tatsächlich diesen Code aufweisen.
