Show your RIGID data log's
  • holco
    holco
    Yesterday I tested the new Hyperin G3 lipo,s in the Rigid with
    the Unilog data logger.
    Setup is exactly like Jan advised, H-Vstabi 4.0, Radix 710SB + Radix 105mm tail blades, +/- 14° pitch, last Idle-Up +/- 15°
    Every flight in the beginning is the same, 5 time's full pitch climb-outs in every mode, the rest is free flying.
    log1=volts-Amp's-rpm (rpm reading's are lost sometime!)
    log2=Wat's-temp engine-temp esc
    log3=height-climb speed
    This are the lipo's, all 2x6S so 12S total
    Outrage XP25 5000mAh 1510g (30 flight's)
    Hyperion VX-G3 4200mAh 1354g (first flight!!)
    Zippy-R 4800mAh 1528g ( 20 flight's)
    In first flight with the Outrage lipo's the rpm were to high because I changed the new high KV Pyro for the older one from my XL with a 14T pinion,
    now the max rpm is 1950.
    Zuletzt geändert von Gast; 30.05.2009, 08:23.
  • drei d
    drei d
    AW: Show your RIGID data log's
    danke
    • holco
      holco
      The Hyperion's seems to be waking up
      4 charge, 6859Watt 44,66V at the peak, to much for the Jive 80+HV!!
      1 flight before with the Outrage lipo's, 5228Watt 42,85V at the peak, no problem for the Jive 80+HV.
      • drei d
        drei d
        unilog 150amp sensor or 400amp?
        • holco
          holco
          400a
          • drei d
            drei d
            boh ey
            how much was the rpm-drop on 6,8kW peak?
            Zuletzt geändert von Gast; 03.06.2009, 15:02.
            • holco
              holco
              1920rpm>1798rpm
              • Stone
                Stone
                Hi Holco,
                what does "..to much for the Jive 80+HV!!" exactly mean? Hard cut off with autorotation? Or slow 30 seconds power down?
                • holco
                  holco
                  Zitat von Stone Beitrag anzeigen
                  Hi Holco,
                  After 65 sec slow 30 seconds power down with a autorotation.
                  • holco
                    holco
                    same type of flight at a fun-flight in Belgium, but after 1.40min power down.
                    • Stone
                      Stone
                      Damn, hope everything went allright. What blink code? Overtemp? Or Overamp?
                      • helijonas
                        • 26.01.2008
                        • 3047
                        • Jonas
                        • Berlin
                        WOW, the Hyperion lipos perform very well !! Awesome peaks...
                        Do you have installed a fan or another cooling element?
                        It seems as if you need a bigger jive
                        Auf die Dower hilft nur Pauer!
                        2x TDR 2 Speed - XL 700 - G570 - M1/M2 - VBCT
                        • upside-down
                          upside-down
                          AW: Show your RIGID data log's - VIDEO
                          I guess you should make a collectioin and buy the camera-man a new pair of glasses
                          • holco
                            holco
                            Don't know, forgot to look
                            • holco
                              holco
                              I use the same model as in the kit but one sice bigger and glued it with Artic-Silver 2K.
                              Bigger Jive has no sense, I have reach the max that the gear can handle, so I co one step back
