Nano QX 3D
  • Der_Basti
    • 17.07.2012
    • 1299
    • Sebastian
    • Abu Dhabi
    [Quad] Nano QX 3D
    Huch was ist denn da durchgesickert
    Also wenn das mal nicht was geiles ist um Spaß zu haben
    Nano QX 3D | HelicoMicro.com
    Und dann noch ein Video
    BLADE NANO QX 3D - YouTube
    Nano QX 3D RTF
    generally
    specifications
    Kit contents
    comments
    The Blade Nano QX 3D feels most comfortable with a decent amount of action at high speed flips , hair -pin turns and especially in inverted flight ! The SAFE technology makes it more flight modes to choose from and provides both a clean flight behavior as well as a helpful self-stabilization . A refined design and reverse motor arrangement make the Nano QX 3D light yet super stable . If you train your 3D action on soft carpet or grass , even crashes usually remain without consequences.
    Aerobatics made --easy
    The SAFE (Sensor Assisted Flight Envelope) technology is a revolutionary electronic attitude stabilization. It causes the Nano QX 3D even in windy conditions consistently good performance zeigt- And for every level of experience , there are the right flight mode. This allows you to fly just as you want it .
    Stability Fashion
    The pitch and roll angles are limited . When you release the joystick , the Quadcopter stabilized itself and returns a stable hover . Class effect : By pressing a button , you can trigger automatic 360 -degree flips in each direction.
    EVO Fashion
    In this mode, you go a step further . Button, the blade alone in the back of flight or pivots back from it. In this case, the controller is not changed , no matter what situation you are in. The self-stabilization and the limitation of the inclination angle are retained.
    3D agility Fashion
    Here are all air tools are disabled. You get the maximum maneuverability for the full 3D experience . In vertical flight are a negative attack and 51-100 % , a positive thrust available at 0-50 % gas.
    FEATURES
    Complete fully assembled quadricopter
    SAFE technology for smooth flying
    Flip 180-360 ° in any direction at your fingertips
    Installed Brightly colored LEDs
    Sturdy , lightweight design with rotor protection
    Robust Corless engines bring positive and negative thrust
    Ultra Micro 4 -in-1 DSMX receiver / ESC / Mixer / SAFE sensor unit
    Incl . Extra set of rotor blades
    1S 3.7V 200mAh E -flite 30C LiPo battery (included )
    Compact USB LiPo charger (included )
    [CENTER]People fly airplanes...Pilots fly helicopters![/CENTER]
  • rcandirc
    • 07.11.2009
    • 675
    • Wien/Aspern
    AW: Nano QX 3D
    War nur eine Frage der Zeit bis der kommt. Sieht aber eher komisch aus. Scheint auch nicht so viel Leistung zu haben.
    Protos 500 stretch, Gaui X5F und Raptor E700
    • reddog
      • 30.11.2012
      • 603
      • 52399 Golzheim
      AW: Nano QX 3D
      Och nööööööööö..... ;-)
        AW: Nano QX 3D
        ...ich will nen Nano QX FPV 3D !!!
        • romsch1
          • 09.10.2007
          • 855
          • Roman
          • Gols-MFC Aero Gols
          AW: Nano QX 3D
          Geiles Teil, Perfekt für mein Rückenflugtraining muß ich leider haben
          Gruß Roman
          Goblin 700C,Goblin 380,Logo 700, Logo 600SX V2,Gaui X3 alles mit V-Stabi und VBAR Control
          • Onkelwoody
            • 19.07.2013
            • 653
            • Duisburg
            AW: Nano QX 3D
            Leider geil!
            zuviel, um es hier aufzuführen :(
            FSC Duisburg
              AW: Nano QX 3D
              Fliegt der im acro wie der jetzige qx. Kannst den gleich im Müll hauen.
              • noch ein Stefan
                • 07.08.2004
                • 7356
                • Neuss
                AW: Nano QX 3D
                Sehr differenzierte Aussage!
                Mein QX fliegt wunderbar im unstabilisierten Modus, allerdings mit 60% Expo drauf.
                Aber wenn der Bauer nicht schwimmen kann liegt es halt an der Badehose .
                Gruß Stefan
                  AW: Nano QX 3D
                  Gruß Stefan
                  Nur leider erlauben es nicht die funken aus den rtf Sets(expo Dr verändern=Computer Sender) und das ist recht ärgerlich. Man kann nicht zu der Erfahrung kommen dass es anders geht. Es sei denn man investiert in eine hochwertigere Spektrum funke was nicht im Interesse einiger Piloten liegt. Schade eigentlich. Darum schwimme ich lieber ohne Badehose
                  • noch ein Stefan
                    • 07.08.2004
                    • 7356
                    • Neuss
                    AW: Nano QX 3D
                    Und wieso schreibst du dann nicht so? Dann wissen die Leute was schlecht ist und können es sich überlegen ob sie es abstellen wollen.
                    Denn generell schlecht ist der Nano ja nun wirklich nicht.
                    Gruß Stefan
                      AW: Nano QX 3D
                      Gruß Stefan
                      Ok mein Kommentar war wirklich etwas primitiv. So mag ich den qx ja. Ich fliege den fpv und bin wunschlos glücklich damit. Aber trotz pa Jahren heli fliegen. Bekomme ich den acro kaum auf die Reihe. Auf Sicht ja in fpv unmöglich.
                      • soundmaster
                        • 29.07.2012
                        • 3784
                        • Otis
                        AW: Nano QX 3D
                        Super für inverted Training im Wohnzimmer. Nicht uninteressant.
                        Scheint mit den 200 mah 30c Lipos vom MCPx V2 befeuert zu werden.
                        Zuletzt geändert von soundmaster; 25.01.2015, 02:11.
                        • Hallodrius
                          • 07.10.2011
                          • 1327
                          • Anselm
                          • Wiesbaden
                          AW: Nano QX 3D
                          Hat jemand eine Ahnung wann der in die Läden kommt?
                          Ist ja nichtmal bei HH in den USA gelistet....
                          Anselm
                          Devo 8s / DX6i
                          Blade 300x / MQX / NQX
                          Protos 500 / MiniProtos
                          • myself
                            • 10.05.2013
                            • 257
                            AW: Nano QX 3D
                            Es gibt dazu keine Infos. Wenn er offiziell (auf der Spielemesse ??) vorgestellt wird, gibt es bestimmt einen Termin :-)
                            • RCAndi83
                              • 16.03.2012
                              • 100
                              AW: Nano QX 3D
                              Bin gerade über die Preise gestolpert...
                              BNF 99,99
                              RTF 119,99
                              bei lindi****.at
                              Lieferzeit 2 Wochen... aber die Erfahrung hat gezeigt, dass sich das öfter länger hinziehen kann...
                              LG,
                              Andi
                              DX8, DS-14, mCPX BL, 130X, 230s, TRex 450, Logo 550sx V2, TRex 700N, TDR
