Hobbywing Update
  • bronti
    • 16.10.2005
    • 3479
    • sven
    Hobbywing Update
    HOBBYWING is proud to announce that all Platinum V4/V4.1 ESCs are now 100% integrated with Vbar Control and Vbar NEO; this means you can setup and tune your HOBBYWING ESCs from your Vbar Control as well as still receive full telemetry data on the radio. Also included in this firmware update are various software optimimzations listed below:
    1) Added support for parameter adjustment via Mikado VBar-Control.
    2) Optimized flight modes: soft start function in "Ext.Gov" (external governor mode) and Throttle response to better match VBar's Governor function.
    3) Optimized accuracy of the ESC current draw in the Telemetry data.
    4) Optimized slow start algorithm in "Heli ELFGov" (elf speed mode) and "Heli StoGov" (storage speed mode) to make a faster and more linear start.
    5) Optimized "Restart Accelerate time" function so that the blades can spool up faster according to the restart time set in the ESC.
    Below is the current firmware version for each ESC:
    Platinum HV 200A V4.1 --- PL-04.1.00-VBar
    Platinum HV 200A V4.1 OPTO--- PL-OPTO04100VBar
    Platinum HV 130A V4 --- PL-04.1.00-VBar
    Platinum HV 130A OPTO V4 --- PL-04100OPTOVBar
    Platinum 150A V5 --- PL-04.1.00
    Platinum 120A V4 --- PL-04.1.00-VBar
    Platinum 80A V4 --- PL-04.1.00-VBar
    Platinum 60A V4 --- PL-04.1.00-VBar
    Platinum 25A V4 --- PL-04.1.00-VBar
    Firmware Update 👇👇👇
    Hobbywing
  • Andi-AS
    • 15.02.2003
    • 652
    AW: Hobbywing Update
    Habe täglich danach geschaut; Heute morgen war es auch drauf...
    Aber irgendwie sind die Versionen identisch; Und die Erweiterung in der EVO Touch immer noch "grau".
    Andi
    Meine Star Alliance (RAW NEO,Vodoo NEO,Logo200; SE NEO AC3X V3)
    • RV
      RV
      Mikado-Heli.de
      VStabi-Support
      • 02.06.2001
      • 7771
      • Rainer
      ich glaube dass die Kollegen das File für den 200er nicht reingepackt haben. Bitte mal HW kontaktieren deswegen.
      • Mugu2176
        • 27.06.2020
        • 215
        • Murat
        Moin Piloten,
        habe meinen HW 80A V4 - Regler auf die neueste Firmware aktualisiert. In meiner VBAR sehe ich im HW-Setup keine Auswahl auf HW Governor Modus (nur HW Regler Modus und HW Regler Store). Welcher davon ist jetzt nun der Governor-Mode? Ist dieser überhaupt verfügbar?
        Die App auf meiner VBAR ist auch aktuell.
        Gruß Murat
        VBAR Touch, Futaba T14sg
        Align 550L, e700 Raptor, Raptor 50
        Spirit, Neo, Heli X
        • Andi-AS
          • 15.02.2003
          • 652
          Moin Rainer
          120 A V4 Regler eben upgedatet. Perfekt funktioniert!
          200 A V4.1 geht nicht, da hast du vollkommen recht!
          Ich schreibe mal Hobbywing!
          Bin gespannt ob die es ernst nehmen.
          Andreas
          • RV
            RV
            Mikado-Heli.de
            VStabi-Support
            • 02.06.2001
            • 7771
            • Rainer
            Der Updater wurde von HW aus nochmals neu hochgeladen - bitte neu ziehen und installieren.
            • Andi-AS
              • 15.02.2003
              • 652
              Danke Rainer
              Eben das ganz nochmal am 200A V4.1 durchgespielt. Funktioniert!
              Ein weiterer Zugewinn für euer System!
              Andi
              • pitsch
                • 19.04.2012
                • 559
                • pitsch
                bei mir wird immer noch der 150 LV in der EVO angezeigt statt der 200HV
                Parameter nicht wählbar (install um heute 17.30)
                gruss pitsch
                • pitsch
                  • 19.04.2012
                  • 559
                  • pitsch
                  so-- ich habe nun die Software von HW komplett deinstalliert (win bereinigt)
                  nach der Neuinstallation geht es, obwohl die genau gleiche Version angezeigt wird wie vorher.
                  aber, gibt es keine Möglichkeit den Verbrauch zu kalibrieren?
                  gruss pitsch
                  • AndreCH
                    • 06.06.2001
                    • 84
                    • andre
                    Macht das Update auch dann Sinn wenn man keine VBar Steuerung hat ?
                    Gruss André
                    • luha
                      • 07.10.2013
                      • 4847
                      • Lutz
                      • Lehrte bei Hannover
                      Weil das alles spezielle VBAR Anpassungen sind, wohl eher nicht.
                      • papads
                        • 07.01.2012
                        • 5575
                        • Werner
                        • Koblenz
                        steht doch in der Beschreibung das außerdem noch verschiedene Software Optimierungen stattgefunden haben.
                        Die Punkte 3-5 sind nicht nur für Vbar User.
                        HOBBYWING ist stolz darauf, bekannt geben zu können, dass alle Platinum V4/V4.1 Regler jetzt zu 100% mit Vbar Control und Vbar NEO integriert sind. Das bedeutet, dass Sie Ihre HOBBYWING Regler über Ihre Vbar Control einstellen und abstimmen können und weiterhin alle Telemetriedaten über das Funkgerät empfangen können. Dieses Firmware-Update enthält außerdem verschiedene Software-Optimierungen, die im Folgenden aufgeführt sind:
                        1) Zusätzliche Unterstützung für die Parametereinstellung über Mikado VBar-Control.
                        2) Optimierte Flugmodi: Softstartfunktion im "Ext.Gov" (externer Reglermodus) und Gasannahme zur besseren Anpassung an die VStabi-Reglerfunktion.
                        3) Optimierte Genauigkeit der ESC-Stromaufnahme in den Telemetriedaten.
                        4) Optimierter Langsamstart-Algorithmus in "Heli ELFGov" (Elf Speed Mode) und "Heli StoGov" (Storage Speed Mode) für einen schnelleren und lineareren Start.
                        5) Optimierte "Restart Accelerate time"-Funktion, so dass die Blätter entsprechend der im ESC eingestellten Restartzeit schneller hochfahren können.
                        Übersetzt mit DeepL Translate: The world's most accurate translator (kostenlose Version)
                        Werner
                        • luha
                          • 07.10.2013
                          • 4847
                          • Lutz
                          Ich war gerade auf dem falschen Dampfer. HW hat ja nur eine Firmware für alles, nicht wie YGE, wo es spezielle VBar FWs gibt.
                          • Keven S
                            Helicoach/MTTEC
                            • 01.07.2007
                            • 2335
                            • Keven
                            • Zwischen Ulm und Heidenheim
                            Es gab immer spezielle Firmwares für VBar bei HW. YGE hat seit vielen Jahren eigentlich nur noch eine Firmware für alles.
                            • pepsi33
                              • 15.12.2009
                              • 472
                              • hans dieter
                              hat schon jemand getestet ob mit dem Vbar Gov. das Heck weg drehen besser wurde ?
                              Und falls ja, welche Einstellungen ?
                              Grüße Hans-Dieter
                              Logo200,Strike 7.1,Specter,Voodoo700, Alien 630,Protos800, Goosky
