Spirit Firmware 3.0
  • SlowFlyer
    • 13.10.2019
    • 282
    • Henry
    • Görlitzer Umland
    Spirit Firmware 3.0
    Spirit FW 3.0.0 und GeoLink FW 1.1.0 seit Heute online:
    Quelle: spirit-system.com
    Sensor Calibration process:
    All Spirit units are utilizing brand new calibration process.
    Calibration is more thorough in a low temperature making flight and rescue more precise.
    Movement detection during calibration is more sensitive, resulting in an additional calibration.
    Completely new algorithms for Rescue and Stabilisation modes:
    New version of revolutionary Sensor Fusion technology for completely all Spirit units is here!
    Rescue and stabilisation modes were totally reworked from scratch.
    It brings significant advancements in precision, reliability and flexibility.
    Model can be powered up, transported and left at any attitude during or after initialization. Yet it has no impact at Rescue and Stabilisation precision.
    Model can be lifted off from an uneven surface without affecting Rescue and Stabilisation modes.
    It can work reliably under the most demanding maneuvers and very harsh environment at the same time.
    GeoLink - Completely new navigation system algorithms:
    GeoLink features can operate more precisely and reliably with any flight style.
    GeoLink Compass precision has been enhanced by one order.
    GeoLink Compass Heading is now indepedent from mounting position in horizontal axes.
    GeoLink is performing many additional calculations making it less dependent on the unit.
    GeoLink know everything about model movements which can be utilized in a new features.
    GeoLink can be mounted at a tilted surfaces from now.
    GeoLink digital protractor feature is more precise and faster.
    GeoLink - Firmware update:
    Firmware updating is more reliable with all Spirit units.
    GeoLink - Connection stability:
    GeoLink logging enablement during model take off is more reliable.
    Old (original) Spirit units are handling communication seemlessly.
    GeoLink - Vertical Correction Gain:
    Vertical Correction Gain range has been increased to 20 - 150%.
    GeoLink - electrostatic immunity increased:
    During high electrostatic discharges connection was prone for freezing. From now it is established again.
    Support for Spirit RS units:
    Full support for brand new Spirit RS units.
    Spirit RS introducing control board and telemetry receiver in a single rigid package!
    Specifications:
    Dimensions: 36.8 x 27.15 x 15.8 mm
    Weight: 23 grams
    Material: Aluminium alloy AL6061-T6
    Input Vultage: 3.5V - 12V
    Sensor: 12-Axis Sensor Fusion
    Processor: 32bit high performance ARM
    More information will be available at Spirit System information channels.
    Extended JETI integration:
    JETI integration has major improvements and new features.
    Improved appearance of the integration menu.
    New verification for the Integration file version mismatch.
    New Setup Wizard that will guide you through entire Spirit setup with all necessary instructions.
    New Vibration Analysis screen - you can view Vibrations at the plot in a real-time (except first Spirit units).
    New BEC Tester that can test power supply of the model.
    New Log Viewer that will allow you to view all flight events in a real-time.
    New Diagnostic screen that will display deflections of all channels and additional details.
    SRXL2 protocol improvements:
    Support for all full-size SRXL2 receivers.
    All SRXL2 based receivers can operate flawlessly now.
    Full integration and telemetry with all Spirit units is working with any SRXL2 receiver.
    Wiring instructions were updated. See SRXL2 Wiki page.
    IMPORTANT: Gyro Gain Channel has been reversed. Default channel reversing can be used now. Please reverse your Gyro Gain channel!
    JETI EX BUS protocol improvements:
    Default channel values with inactive receiver connection were updated.
    All channels were centered.
    Control loop enhancements:
    New optimizations for all units in the control algorithms allowing even faster regulation processing.
    Algorithms require less computing power which is beneficial especially for the first Spirit units.
    Calculations are performed in two separate processor cores.
    Tandem Helicopter support:
    Support for twin-rotor tandem helicopters has been improved.
    Elevator regulation is less sensitive making reactions more equal for all axes, resulting in a more stable flight.
    Spirit 2 flight performance:
    Flight characteristics were improved with faster response time.
    Special Function - P: Pirouette Consistency:
    Adjustable range was changed to 50 - 250.
    Spirit Settings - firmware update:
    Servo signal is turned off before flashing to prevent unexpected movement.
    Das sind viele ßnderungen
    "Glück ab, gut Land"
    Henry
  • Crashpilot1977
    • 15.05.2017
    • 2292
    • Marek
    • Hontheim
    AW: Spirit Firmware 3.0
    Hab jetzt die neue Firmware auf meine zwei Spirit Pros drauf gespielt. Werde die Tage mal testen ob eine ßnderung spürbar ist.
    Goblin Kraken 700 S
    Chronos 700 V2
    Protos 700 EVO
    • baccardi
      • 17.03.2010
      • 263
      • Herbert
      • Weistrach NOEN
      dann Kontrollier die Rescue Bewegung noch mal, im spirit Forum gab es da schon mal Probleme.
      Nur so ein gedanke, ich habe noch nicht geupdated.
      ALZRC420, Spektrum DX8 G2
      REX 550 DFC Spirit Pro, LOGO690SX V2
      lg Herbert
      • databeer
        • 06.06.2006
        • 41
        • Gerhard
        • Innsbruck
        http://spirit-system.com/phpBB3/view...hp?f=20&t=3866
        Habe auch auf 3.0 upgedatet. Auf zwei Helis. Beide mit Spirit 2. Einer davon mit Geolink. Absolut problemlos. Auch die Rettungsfunktion funktioniert wie sie soll.
        Lg
        • enied
          • 17.06.2017
          • 3076
          • Eugen
          • Tirol
          Habe jetzt auch einen Heli mit Spirit PRO und Geolink auf 3.0.0 / 1.1.0 aktualisiert. Alles problemlos und die Tests auf der Werkbank sehen gut aus.
          VG
          • heli jürgen
            • 20.03.2008
            • 1159
            • Jüergen
            • Frechen, Köln,MSC Ober-Niederaussem
            Was ist mit Rescue Bewegungen gemeint?
            Das bei der Rettung TS Negativ geht?
            Gruss Jürgen
            Zuletzt geändert von heli jürgen; 15.04.2020, 12:54.
            Logo 600SE--Low RPM
            Diabolo 550 , TDSF
            Jeti DC16II,MZ 24 pro und Junsi 308
            • Benny77
              • 04.04.2012
              • 1543
              • Benjamin
              • Althengstett
              Hab's gerade auf meine zwei Spirits der ersten Generation aufgespielt. Lief problemlos. Check der Grundfunktionen inkl. Rettung verlief gut.
              Werde auch die Tage erste Testflüge machen.
              [FONT="Verdana"]Gruß Benny[/FONT]
              LOGO 550SE V2, T-REX 470LM + Spirit + Graupner MZ24; XK K110
              • heli jürgen
                • 20.03.2008
                • 1159
                • Jüergen
                Neue SW ist da. 3.0.1
                Logo 600SE--Low RPM
                Diabolo 550 , TDSF
                • Acrobert
                  • 03.10.2019
                  • 37
                  • Berthold
                  Voodoo 400 / Voodoo 700 / T-Rex 150
                  • Milindur
                    • 12.04.2020
                    • 19
                    • MFC Kamen (Dortmund)
                    Wird bisher nur im Spirit Forum bereitgestellt und soll in den nächsten offiziell auf der Webseite erscheinen.
                    • Benny77
                      • 04.04.2012
                      • 1543
                      • Benjamin
                      • Althengstett
                      Hab's befürchtet, dass ich gleich nochmal updaten kann
                      Was ist neu?
                      • Milindur
                        • 12.04.2020
                        • 19
                        Was ist neu?
                        Siehe Diskussion im Forum. Soweit ich verstanden habe, geht es um Folgendes: Die neue Firmware 3.0 benutzt weitere Features der verbauten Sensorik, die in älterer Firmware bisher nicht verwendet wurde. Dabei scheint es nun einige sehr wenige Spirit Module zu geben, wo die Sensoren möglicherweise nicht in Ordnung sind und diese erweiterten Features nicht richtig funktionieren bzw. wo eine zusätzliche Kalibrirung notwendig ist. Das könnte z.B zu Fehlern bei der Rettung führen. Die Version 3.0.1 soll dies nun erkennen und im Konfigurator dann warnen.
                        Details wird es dann sicherlich in den Release Notes geben.
                        • Acrobert
                          • 03.10.2019
                          • 37
                          • Berthold
                          Was ist neu?
                          • heli jürgen
                            • 20.03.2008
                            • 1159
                            • Jüergen
                            Ich bleibe erstmal bei 2.0.8 da funktioniert doch alles wie es soll wenn alles richtig Programmiert ist.Die Rettung funktioniert Problemlos,ob direkt oder per Höhenlimit.FBL arbeitet auch super,wenn man sein Setup einstellen kann.
                            3.0 ist deshalb auch zur zeit out of Order.
                            Deshalb
                            Never change a running system?
                            Gruß jürgen
                            Logo 600SE--Low RPM
                            Diabolo 550 , TDSF
                            • Benny77
                              • 04.04.2012
                              • 1543
                              • Benjamin
                              • Althengstett
                              hab jetzt auch mal ins Spirit Forum geschaut - der Fehler ist wohl, dass durch die nicht richtig funktionierenden Sensoren, die Taumelscheibe bei der Rettung horizontal nicht richtig ausgerichtet wird. Ich hatte das Problem nicht, habe aber dennoch die 3.0.1 Version aufgespielt. Somit sollte es das safe sein.
