RadioMaster NEXUS FBL / RP3-H ELRS Empfänger
  • MrMikeBravo
    • 10.04.2023
    • 157
    • Kilian
    Radiomaster hat heute ein neues FBL für RotorFlight 2 vorgestellt:
    Hier mal die Features:
    • The NEXUS Helicopter flight controller is designed from the ground up specifically for Rotorflight 2.0
    • Equipped with an advanced STM32F722 MCU and TDK 6-axis MEMS motion tracking device, which combines a 3-axis gyroscope and a 3-axis accelerometer
    • Built-in Black Box: A large 128Mb of onboard flash memory ensures you can log all your flights for fine-tuning and adjustment
    • Locking connector system compatible with our Plug'n'Play solder-free RP3-H ExpressLRS receivers, You can rest assured that there will be a stable connection between the control unit and the receiver (RP3-H not included)
    • Features multi-function ports (UART) for future expansion
    • The NEXUS flight controller is compact and rugged. The CNC case not only protects the internal components but acts as a heat sink to help keep the electronics cool
    • The NEXUS measures just 41mm x 25mm and is only 13mm high, making it a perfect fit for any size heli build, including 250/450/500/550/600/700 helicopters
    • The NEXUS flight controller supports a wide range of Tail Motors and Tail ESCs (760μs / 1520μs)
    • A variety of receivers are supported, including CRSF, ELRS, GHOST, S.BUS, SUMD, IBUS, XBUS, EXBUS, PPM, MSP, DSM2, DSMX, and F PORT
    • The device has multiple independent power supplies that minimize noise when reaching 1.8V. It includes 1.8V for Gyro, 3.3V for the MCU, and 5.0V for the external interface
    • Ultra light-weight and flexible USB-C extender cable is included to help in situations where the USB-C port may not be easy to reach. Made as light as possible because every gram counts and uses flexible silicone wires to prevent vibration transfer to the control unit
    ​Und hier die Technischen Daten:
    • Item: NEXUS Heli Flight Controller
    • Firmware: Rotorflight 2.0
    • MCU: STM32F722RET6
    • Gyro (IMU): ICM-42688-P
    • Flash Memory (Black Box. IC): 128Mb (W25N01GVZEIG)
    • Barometer: SPL06-001
    • Uart: 6 - DSM[UART1], S.BUS[UART2], A-CRSF[UART4], PORT-B[UART6], PORT-C[UART3]
    • Servo: 4 - S1, S2, S3, TAIL
    • Rpm Sensor: 1 - FROM ESC FREQUENCY SENSOR
    • Receiver Support: CRSF, ELRS, GHOST, S.BUS, SUMD, IBUS, XBUS, EXBUS, PPM, MSP, DSM2, DSMX
    • Voltage Supply(DC): 5 - 12.6V
    • A-B-C Serial Port Power Output: 5V - 2.0A
    • DSM Serial Port Power Output: 3.3V - 0.5A
    • Telemetry: S.BUSH, HoTT, S.Port, MSP, EDGETX, ELRS
    • ESC: PWM, Oneshot, Multishot, Dshot
    • Support Tail ESC: 760μs/1520μs Servo
    • Support Tail Motor: Yes
    • Demensions: 41.3 X 25.4 X 13.1mm
    • Weight: 16.8g​
    Passend dazu wurde auch noch ein ExpressLRS Empfänger vorgestellt, der Plug & Play mit dem Nexus FBL kompatibel ist.
    • Perfect for helicopters and any application that needs a rugged cased serial receiver
    • Plug'n'play solder free RP3-H ExpressLRS receivers compatible with NEXUS Heli flight controller
    • Optimized PCB design for better heat dissipation
    • LNA for better receiver range
    • PA for better telemetry range
    • Antenna Diversity for improved signal stability and range
    • Built-in a TCXO (temperature compensated crystal oscillator)
    • Automatically detects voltage telemetry of external battery voltage or receiver battery/ESC BEC voltage
    • Compatible with all 2.4GHz ExpressLRS modules and transmitters with built in 2.4GHz ExpressLRS
    Specifications
    • Item: RP3-H ExpressLRS 2.4GHz Nano Receiver
    • Type: ISM
    • MCU: ESP8285
    • RF Chip: SX1281
    • Telemetry RF power: Max 100mW
    • Antenna: 150mm 2.4GHz Antenna x2
    • Frequency Range: 2.404 - 2.479 GHz
    • Maximum receive refresh rate: 500Hz / F1000Hz
    • Minimum receiver refresh rate: 25Hz
    • Working voltage: DC 4.5 - 8.4V
    • Battery voltage detection range: DC 4.0 - 35V
    • Weight: 5.1g (Including two antenna)
    • Dimension: 28mm*24mm*8mm
    • Firmware Version: ExpressLRS v3.3.1 pre-installed
    • FW Target: RadioMaster RP3-H Diversity 240
    Zuletzt geändert von thomas1130; 15.05.2024, 14:22.
  • MrMikeBravo
    • 10.04.2023
    • 157
    • Kilian
    Und Jonas hat auch schon ein Video dazu auf YouTube veröffentlicht:
    • Johnny
      OMPHOBBY
      • 27.11.2010
      • 5557
      • Jonas
      • Wherever
      Sehr gut, alle wichtigen Infos haben es schonmal bis hierher geschafft. Stehe für Fragen gerne zur Verfügung.
      Jonas
      • thomas21
        • 07.03.2010
        • 1170
        • Gelsenkirchen und Umgebung
        Dann kommt gleich die erste . Ist die Rotorflight SW auf dem NEXUS schon installiert oder muss diese dazugekauft werden?
        Tron7.0/ RAW / Kraken 700/Protos 800 EVO/OXY HF / Specter 700
        • Johnny
          OMPHOBBY
          • 27.11.2010
          • 5557
          • Jonas
          • Wherever
          Rotorflight 2 ist Open Source und damit per Definition kostenlos, kaufen musst du da gar nichts. Nexus kommt damit vorinstalliert und vorkonfiguriert. Hat auch so Spielereien wie Rescue direkt mit drin ohne jeglichen Aufpreis. Du kannst dem Projekt aber gerne eine Spende zukommen lassen wenn du möchtest, das hilft der weiteren Entwicklung.
          Jonas
          • pope1701
            • 12.01.2022
            • 547
            • Bei Stuttgart
            Gibt es presets für verschiedene Heligrößen, dass man die config nicht von null anfangen muss?
            Erst Hub, dann Schraub.
            • Johnny
              OMPHOBBY
              • 27.11.2010
              • 5557
              • Jonas
              • Wherever
              Fragen zu Rotorflight selbst halte ich hier für besser aufgehoben: https://www.rc-heli.de/forum/technik...ahrungs-thread
              Jonas
              • jumphigh
                • 16.12.2009
                • 4141
                • Allstedt
                Warum werden die FC immer teurer? Liegt es am Krieg? Jedenfalls waren Copter-FC für unter $50 vor nicht zu langer Zeit gut erhältlich.
                Weiterhin hätte man den ELRS-Empfänger auch gleich mit integrieren können, Platz muss bei dem "Trumm" genug sein. Schade, das Ding ist kein Ersatz für (ver-)alte(te) Regelungen kleiner Chinesen-Helis, die eh keine großen JR-Servo-Stecker haben.
                Grüße von Andreas
                • xbutz
                  • 14.11.2012
                  • 116
                  • Dennis
                  • Hildesheim
                  Das ganze noch für dien kleinen M1 😎
                  • Leroy
                    • 04.01.2015
                    • 946
                    • Leo
                    • MG Urdorf (CH)
                    Schade, dass nur FPort unterstützt wird und nicht FBUS ... nur so von wegen Geschwindigkeit
                    • pope1701
                      • 12.01.2022
                      • 547
                      • Bei Stuttgart
                      Ich finde gut, dass das ein Extrateil ist. ELRS ist noch nicht verbreitet bei helis, in der Kombi würde Nexus keine Marktanteile gewinnen. So kann es jeder am System seiner Wahl zumindest Mal ausprobieren.
                      • Michldigital
                        • 27.05.2009
                        • 1570
                        • Maik
                        • 35625
                        Naja, immerhin haste hier ein vernünftiges Alu-Gehäuse für den Wärmeaustausch drumherum. Und den brauchste beim Heli auf jeden Fall.
                        Der Controller liegt ja nicht so frei wie im Copter.
                        Ja, ich hätte auch gern einen ELRS Rx integriert gehabt. So hat man wieder das zusätzliche Geraffel.
                        Aber egal, wird gekauft. Mal schauen, ob es irgendeinen Unterschied zum Flydragon gibt.
                        • Michldigital
                          • 27.05.2009
                          • 1570
                          • Maik
                          • 35625
                          Es fliegt eh bald jeder ELRS
                          • pope1701
                            • 12.01.2022
                            • 547
                            • Bei Stuttgart
                            Sicher
                            • toni67
                              • 20.04.2022
                              • 323
                              • Toni
                              • Truttikon / TG
                              Wozu wird für ein FBL ein weiteres FBL benötigt? Oder was habe ich falsch verstanden?
                              Gruss Thomas
                              Soxos Strike 7.1L | Tron 5.8 | TRex 470LM | OMP M2 + M2 Evo | Jeti DS-16v2
