Goblin RAW
  • bronti
    • 16.10.2005
    • 3490
    • sven
    #1021
    AW: Goblin RAW
    Zitat von helijonas Beitrag anzeigen
    Was wiegt ne Specter WC Edition Mechanik nochmal im Vergleich? Bronti du wusstest das doch?
    XLpower - Specter 700 World Champion Edition - Kit
    Eine der leichtesten voll belastbaren 3D Mechaniken am Markt, ca. 2495g mit Rotorblättern, ohne Elektronik (Rapid 690+115)
    690er Latten rapid 370g
    115 heck 13g
    2495 -Latten wären 2112g
    bin mir aber nett sicher ob der specter mit der ganzen WC Edition das Gewicht noch hält
    das war 2018 Gewicht der Mechanik mit jeglichem Befestigungsmaterial, Haube und Akkurutsche liegt bei ca. 2089g. Mit CFK Heckrohr bei ca. 2044g.
    1879g leere Mechanik mit allen Servoschrauben drann.
    2089g mit Akkuschiene und Haube.
    Quelle helifreak 2018
    Airframe Weight
    I built the machine without installing any electronics just to see what the bare airframe weighs. The only thing installed was the motor since you kind of have to in order to get the pinion, motor mount, and counter-bearing assembly installed. The motor was precisely weighed before installation and subtracted from the AUW. First, to pre-empt the questions, this weigh-in includes everything to complete the airframe.
    Specifically it includes:
    - The battery tray and associated hardware.
    - All servo mounting hardware and included servo arms (again no servo's installed, just the hardware for it).
    - Pushrods, links, and boom supports.
    - Blade grip bolts and nuts for main and tail.
    - Canopy
    What is does NOT include:
    - Any electronics
    - Blades
    - Blade holder
    - Any Velcro, zip-ties, or misc hardware that may be needed for electronics and battery installation.
    With that, my bare airframe weight came out to 2,110 grams. Very light! With my setup, take-off weight should be about 5.05kg. And that's with 2x 6s 5500 packs. Hope you find this useful.
    raw kannst abspecken titanwellen Lande Gestell und 35 mm Carbon Heckrohr
    Zuletzt geändert von bronti; 07.02.2021, 12:52.
    • goone75
      • 20.06.2012
      • 3965
      AW: Goblin RAW
      Zitat von heliklaus Beitrag anzeigen
      Das Gewicht ist jetzt da: 2290g original nach Anleitung zusammengebaut ohne Blätter und ohne Elektronik.
      VG Klaus
      Und wie immer die Gretchenfrage: Ist die Akkuschiene bei dieser Gewichtsangabe mit gewogen worden und falls nein, was wiegt die mit Klettbandschlaufen?
      • bronti
        • 16.10.2005
        • 3490
        • sven
        #1023
        AW: Goblin RAW
        VG Klaus
        2290g
        dann war meine schätzung ja net schlecht lol
        mit 2263g
        ihr wisst die differenz ist wegen dem vielen loctite gell Klaus
        RC-Heli Community - Einzelnen Beitrag anzeigen - [Goblin 700] Goblin 700, Kraken 700, Goblin RAW unter 5 kg
        • trailblazer
          • 06.10.2008
          • 1742
          • Andre
          AW: Goblin RAW
          Also ich finde eure Gewichtsorakeleien ja einfach nur noch faszinierend
          Goosky RS7 Ultra, Goblin RAW Nitro, Goblin RAW 420 Comp
          VBar Touch & EVO
          • bronti
            • 16.10.2005
            • 3490
            • sven
            #1025
            AW: Goblin RAW
            Wir sind halt ein Medium und können die Fakten auch belegen!
            Außersinnliche Wahrnehmung ,die nicht durch bekannte sinnliche Erfahrungen oder Wissensquellen erklärbar sind. Voodoo ach das war ja was vom Plöchinger
            Manche Leute haben spaß am Modellbau!
            • Drachentöter
              • 07.05.2006
              • 787
              • UnterschleiÃ?heim
              #1026
              AW: Goblin RAW
              Das mit dem 35 mm Carbonheckrohr sehe ich, bei einem ungünstigen Absturz kontraproduktiv, wenn keine gescheite Sollbruchstelle vorhanden ist. Beim Alu Heckrohr wird dieses ja verbogen.
              Fliege selber eine solche ,, dicke Männersache,, von einem anderen Hersteller. Die Sollbruchstelle sind da die Seitenteile ( Sorry Marco)= Kostenfaktor je Seite 125 €.
              Gruss Thomas
              Zuletzt geändert von Drachentöter; 07.02.2021, 14:17.
              • heliklaus
                • 10.02.2007
                • 810
                AW: Goblin RAW
                Mechanik komplett, natürlich auch mit Akkuschiene und Klettband ( 15g )! Sonst macht das alles ja kein Sinn!
                Tron 7.0 Dnamic, Tron 7.0 EB, Tron 7.0 Elite, Goosky RS6, Goosky RS7 Ultra, Banshee 850
                • heliklaus
                  • 10.02.2007
                  • 810
                  AW: Goblin RAW
                  2290g
                  mit 2263g
                  Ich schraube ihn noch mal auseinander und lasse das Loctite weg, dann habe ich 2263g :-)
                  • heliklaus
                    • 10.02.2007
                    • 810
                    AW: Goblin RAW
                    Mal ein anderes Thema.
                    An die die den RAW schon gebaut haben:
                    Meiner Meinung nach gibt es auf Seite 15 in der Bauanleitung einen Darstellungsfehler.
                    Der Lagerbock mit den zwei Führungsrollen soll laut Zeichnung mit der dickeren Seite 4,9mm auf die Seite von dem Riemenspanner ( Bild 1 ). Dann sitzt die Riemenrolle aber ganz knapp unter dem Riemenspanner ( 0,1mm ) und hat eine andere Höhe als die Riemenspannerrolle. Was eigentlich keinen Sinn macht.
                    Es gibt zwei Bilder von SAB die das auch bestätigen, das der Lagerbock andersrum sitzen muss. Bei Bild zwei sieht man ganz deutlich, das die Riemenrolle viel mehr Luft hat und bei Bild 3 ist auch das Schraubengewinde auf der Riemenspannerseite weiter drinnen.
                    Die zwei Bilder bestätigen meine Vermutung.
                    Die, die ihn schon gebaut oder noch bauen werden, könnten sich das noch einmal anschauen ob ich da recht habe.
                    Zuletzt geändert von heliklaus; 07.02.2021, 15:58.
                    • bronti
                      • 16.10.2005
                      • 3490
                      • sven
                      #1030
                      AW: Goblin RAW
                      Goblin RAW Time Lapse Build Video - YouTube
                      • goone75
                        • 20.06.2012
                        • 3965
                        AW: Goblin RAW
                        Bin ich absolut deiner Meinung. Berücksichtigen aber nicht immer alle bei der Gewichtsangabe zu einer Mechanik. So auch nicht SAB beim Kraken seinerzeit.
                        • heliklaus
                          • 10.02.2007
                          • 810
                          AW: Goblin RAW
                          Dann werde ich es, wie nach der Zeichnung, so lassen.
                          • Nappi82
                            • 10.05.2020
                            • 153
                            • Louis
                            #1033
                            AW: Goblin RAW
                            Hallo zusammen
                            Weiss jemand für was das Säcklein Rigid Assembly gut ist? Habe das nicht gebraucht..
                            Lg Nappi
                              • 12.10.2016
                              • 8546
                              AW: Goblin RAW
                              L...-H.... hat schon Hauben, Heckrohre und Akkuluken in vielen Farben gelistet.
                              • heliklaus
                                • 10.02.2007
                                • 810
                                AW: Goblin RAW
                                Zitat von Nappi82 Beitrag anzeigen
                                Hallo zusammen
                                Lg Nappi
                                Wenn du die Gummidämpfung nicht einbaust, kannst du die Stabbi-Platte fest verschrauben.
