Fachthread zum Raptor E700 - kein Laberthread!!!
  • Dirk S
    • 08.05.2012
    • 1615
    • Dirk
    #31
    AW: Rapi E 700
    Hab ich ein Glück, war schon auf den 720 scharf nun wird es der 700. Der Preis ist für die Größe mehr als akzeptabel. mal schauenmwas die Combo kosten wird. Starrantrieb und Pfeilverzahnung plus die neue Haube. Was will ich mehr.
    Dirk
    • Pille95
      • 08.07.2012
      • 174
      • Philipp
      • MSC Schöneck
      #32
      AW: Rapi E 700
      Ok ein Post noch....
      Zitat vom Meister (Nick Maxwell) persönlich:
      Hey Guys,
      Just a few comments on the new E700 regarding the questions popping up.
      The battery tray can be inserted from the front or back, and is a quick release that works just as easy as the E720's. Actually, it will be a bit easier as you do not need to tip the model, the packs are changed on the skids. Same with the option E820 tray (also work on the E720 for those interested in using stick form on the E720 if used with the new front triangle carbon frame peices).
      As for the the question of the E700 being geared towards being just a sport version, absolutly not. The model was designed to increase 3D performance. The best way to describe the E700 is another class model, that will give you the performance of the larger model, but with the ability to keep the costs lower. While the E720 performs best on 710 size blades and nessacary motor/pack set-up, the E700 will be able to get the same or better performance with a 690 size blade and heli set-up.
      One key factor mentioned above, the new boom mounted servo. On E820, that will also be able to fit on the E720. On the E700, you'll notice the servo still remains stationary to the frames. So the boom still can be independantly removed/maintained without having to unwire the servo.
      Hope this helps with the general things that might come to mind when seeing the new model.
      Nick
      Wie man sich täuschen kann
      Zuletzt geändert von Pille95; 01.02.2013, 18:50.
      Raptor E700
      Team Heligarage Deutschland
      • Mike1503
        • 02.01.2009
        • 3236
        • Mike
        #33
        AW: Rapi E 700
        Pille bitte ßbersetzen ;-)
        Das hört sich ja immer besser an kein 700 und kein 600 genau meine Grösse.Man bin ich heiss auf mehr Infos.
        Gruss Mike
        • Pille95
          • 08.07.2012
          • 174
          • Philipp
          • MSC Schöneck
          #34
          AW: Rapi E 700
          In Kurzform:
          Die Akkurutsche kann von vorne und von hinten eingeschoben werden.
          Auch für 3d designed, er beschreibt ihn als anderes Modell, dass im Gegensatz zum E720 für 690er Blätter ausgelegt ist, der E720 eher für 710er.
          Er soll mindestens die gleiche Performance wie der E720 haben.
          Außerdem hält der E700 die Kosten niedriger und gibt die Performance von einem Größeren Modell.
          Gruß Philipp (wie gesagt nur die Kurzform und nur das über den E700)
          Raptor E700
          • be1974
            • 20.10.2008
            • 633
            • Bernd
            #35
            AW: Rapi E 700
            hört sich gut an. Voltmaster hat ihn schon gelistet
            • Robert Englmaier
              ( Roben155 )
              • 02.11.2010
              • 8957
              #36
              AW: Rapi E 700
              Zitat von vw-bussmann Beitrag anzeigen
              Die Haube im Hintergrund der beiden Helis sieht mal richtig scharf aus .
              Grüsse Robert
              • chris 1972
                • 22.08.2007
                • 1346
                • Weiden i.d. OPf
                #37
                AW: Rapi E 700
                Wenn man den mit 10s 3300 MaH Akkus fliegen könnte, wäre der Heli auch für mich interessant.
                Christian
                Logo 550, Voodoo 400;600, Raptor E720, Raptor G4
                • Henning Piez
                  • 23.10.2001
                  • 3345
                  • Henning
                  • FMSG-Waldenbuch - Milan Landesbergen
                  #38
                  AW: Rapi E 700
                  Ist nen total interessanter Heli... Dürfte die Gebrauchtpreise für die 720er ziemlich drücken... Find ich mutig von TT. Konkurrenz im eigenen Stall zu den Edelmodellen. VW wagt keinen V6 Diese im Passat im den Audis nicht Konkurrenz zu machen, TT ist da mutiger,,,,
                  euer Henning Piez (ENSONIC)
                  TDR II, Diabolo 550+700, Jeti DS16
                  • vw-bussmann
                    • 03.01.2007
                    • 1518
                    • Oliver
                    • Kirn/Bad Sobernheim (Verein)
                    #39
                    AW: Rapi E 700
                    Wohhh ist das ne tolle Arbeit .
                    My Tube
                    • PeterLustich
                      CopterFactory
                      • 08.09.2009
                      • 2586
                      • Verl & Umgebung, MFG-Heideflieger
                      #40
                      AW: Rapi E 700
                      WOW, die erste Raptorhaube die mal ganz ordentlich aussieht von der Form und nicht so schrecklich wie die Raptorhauben sonst...hätte nie gedacht das ich das mal sage...
                      Aber diese Konstruktion...ich weiß ja nicht. Bin ja eigentlich kein Feind von Push Pull, ehr Fan, aber warum muss man da so eine abenteuerliche ßbersetzung reinbauen wenn man im Vorfeld weiß das man einen FBL Heli baut?
                      • Uwe Z.
                        • 14.08.2005
                        • 9887
                        • Uwe
                        #41
                        AW: Rapi E 700
                        Ja gut.. das ewige Thema, genau so wie Riemen oder Welle. Beides geht und über beides kann man sich ewig den Kopf zerbrechen. Beim fliegen und bolzen merkt man wohl keinen Unterschied. Mein Rex 550 hat kein Push Pull... und wenn mir die Servos ansehe, die jetzt ca 1.5 Jahre drinnen sind, haben die mehr Spiel als meine anderen die seit 4 Jahren in Push Pull Helis sind. Sind die DS 620 und DS 610 sind das.
                        Wie gesagt.. gefällt mir ein Heli ist es mir zumindest egal was drinnen ist. Ob jetzt Welle oder Riemen oder Push Pull oder Direkt. Aber beim Chassi bin ich Eigen... das muss CFK sein. Also kein G10 oder Plastik. Auch wieder so ein Thema....
                        • faxxe
                          • 11.05.2007
                          • 1407
                          • heimo
                          • Graz-Weiz
                          #42
                          AW: Rapi E 700
                          Abgesehen von einem moderneren Haubendesign wirken die TT Helis immer noch wie aus der RC Kreidezeit.
                          Irgendwie zuviel "klassik" trotz Innovationen.......absolut nicht meines.
                          Just my 0.02$
                          -Heimo
                          > Raptor e720
                          > Mikado VBar Control
                          • PeterLustich
                            CopterFactory
                            • 08.09.2009
                            • 2586
                            #43
                            AW: Rapi E 700
                            Wie gesagt nicht falsch verstehen, ich bin ein Freund von Push Pull. Nur eben diese abenteuerliche ßbersetzung macht meiner Meinung nach keinen Sinn. Das es funktioniert weiß ich.
                            • chris 1972
                              • 22.08.2007
                              • 1346
                              • Weiden i.d. OPf
                              #44
                              AW: Rapi E 700
                              Hi Uwe,
                              also läuft bei Dir wieder mal Alles auf einen Beaubericht raus.
                              Wenn ich die Akkufrage klären kann, wäre der Heli auch interessant für mich.
                              3300er hätte ich als 10S oder 12S. Da wird sich doch was finden lassen....
                              lG
                              Christian
                              • Uwe Z.
                                • 14.08.2005
                                • 9887
                                • Uwe
                                #45
                                AW: Rapi E 700
                                Na ja.. du meinst gleich das neue GT5.2 in den neuen 700er bauen. Das wäre jetzt nicht so das Problem.
                                Nur was für einen Motor und Regler macht man da jetzt rein. Mein Gefühl sagt mit, das der Heli Jive 120 und ein Pyro 700 wieder rein sollten. Das Zeug läuft bei mir sowas von sorgenfrei seit über einem Jahr.
                                Mein Sparschwein verliert damit aber dann seine Lebensgrundlage.
                                Und ich hab schon 7 Helis im Hobby Keller stehen. Wobei da schon noch Platz wäre für mehr.
