Tron 5.5
  • bronti
    • 16.10.2005
    • 3479
    • sven
    #121
    AW: Tron 5.5
    Zitat von pitsch Beitrag anzeigen
    Und Er kann auch low- Dario und der Heli
    leider nur ein FBlink
    https://www.facebook.com/neuenschwan...1837075384052/
    low glaub icht net
    Dario Neuenschwander with his Tron5.5 with Low RPM. - YouTube
    • bronti
      • 16.10.2005
      • 3479
      • sven
      #122
      AW: Tron 5.5
      nun online
      ABOUT US Performance Helicopters
      Hello everyone
      We are very happy to go online now!
      1. The site is 5K display optimized and will give you a new superb visual experience into the last details about the Tron 5.5.
      2. The online Shop with the prices and spare parts will be opened in mid-February.
      3. Dealer requests will proceed and verified. The procedure is explained on the home-page.
      DETAILS:
      Release date: 10-march-2020 @Rotorlive in Germany.
      Wide battery compartment with quick lock and release system.
      Light, yet very stiff and robust.
      Mini or full-size tail servo option.
      Motor mounting features a bearing block supported pinion, reducing overall wear on the power system and drive train.
      Accepts a wide range of motor sizes. 3225, 4020, or 4025 series fit with easy. From 1000KV-1350KV for 6s (5mm shaft diameter )
      Octa boom design with oval side shapes, no boom supports needed.
      Capable to use a wide range of lipo batteries. 6,8,10 or even 12S. (6S-4500mAh to 5500mAh recommended).
      Perfectly thought-out servo layout in conjunction with the FBL system and ESC.
      Easy cable routing with various options to ensure a clean setup. Modern, sporty and functional design.
      High visibility canopy for perfect orientation in flight.
      Recommended main blade size 550-560mm. Tail blade size 86-93mm.
      Sustainably produced.
      Zuletzt geändert von bronti; 24.01.2020, 15:05.
      • Mabuto
        Supporter XNova
        • 12.05.2010
        • 105
        • Ivo
        #123
        AW: Tron 5.5
        WOW die Seite ist aber mal ne visuelle Ansage!
        • parkplatzflieger
          • 18.03.2012
          • 8994
          #124
          AW: Tron 5.5
          Das wird schwierig. Die RL beginnt erst am 14.03.2020 .......
          Torsten
          Voodoo 600, Logo 600SX
          Spektrum, Spirit, Heli X
          • HeliHans
            • 15.01.2018
            • 1120
            • Oberoesterreich/Muehlviertel
            #125
            AW: Tron 5.5
            Für die Tron - Jungs beginnt sie am 10. schon. Das muss ja ein Mega-Stand werden!
            • Leroy
              • 04.01.2015
              • 1035
              • Leo
              • MG Urdorf (CH)
              #126
              AW: Tron 5.5
              Also bei mir steht:
              Release date: 14-march-2020 @Rotorlive in Germany.
              Sind fix, die Jungs :-)
                • 11.10.2016
                • 8544
                AW: Tron 5.5
                Das ist wohl denen ihr Anreisetag. Ist doch keine Affäre.
                P.S. Will nicht wissen wie lange WOH jedes Jahr an ihrem Stand schrauben.
                  AW: Tron 5.5
                  Der WoH Stand bleibt bestimmt stehen.
                  Muss das nächste Mal auf dem Pferderennen mal nachschauen.
                  • bronti
                    • 16.10.2005
                    • 3479
                    • sven
                    #129
                    • Leroy
                      • 04.01.2015
                      • 1035
                      • Leo
                      • MG Urdorf (CH)
                      #130
                      AW: Tron 5.5
                      Pre-Production Kits sind scheinbar da
                      • bronti
                        • 16.10.2005
                        • 3479
                        • sven
                        #131
                        AW: Tron 5.5
                        Quelle Helifreak
                        Dear all
                        The main problem is that the facts are always twisted. Synergy and Yintec story is a diffrent one than the Tron. Why not let use a scientific way to determine if it is a clone/theft whatever. Not based on beliving based on facts.
                        All previous named allegations are ridiculous. In my opinion, Tron5.5 is superior to Synergy 516 in many ways.
                        here are a few:
                        -battery tray much easier handling
                        -alignment of tail not needed
                        -Motor mount pinion support
                        -design
                        -small compact main gear
                        -dampened tail
                        -servo layout
                        -head geometry
                        -double support tail pitch slider
                        -easy and clean servo wiring
                        -Due to the tube stiffener no 3rd bearing support needed( easier to maintain and to remove the belt for traveling)
                        Anyone who believes in the clone/theft story should create a list and share the list with all of us. I will then compare the parts in the list 1: 1 and document them. I'm looking forward to the list I-m already excited.
                        • TheFox
                          • 28.10.2016
                          • 7876
                          • Ingolstadt/Bayern
                          #132
                          AW: Tron 5.5
                          Diese Diskussion ist auf HF gut aufgehoben. Nichts Neues dabei, die Fakten und Stellungnahmen der Beteiligten sind ja bereits hier gepostet worden. Bei HF auch, wenn Dario nicht lesen kann oder will....
                          • bronti
                            • 16.10.2005
                            • 3479
                            • sven
                            #133
                            AW: Tron 5.5
                            2264 G. Check again with all equipment below
                            -Scorpion HKIV 4025-1100KV
                            -Scorpion Tribunus II 120A
                            - KST X15-1208 ß 3 pcs
                            - KST X15- 755X ß 1 pcs
                            - RT 560 mm. + 95 mm.
                            - V link
                            • päde
                              • 17.09.2010
                              • 799
                              • Patrick
                              • 8330 Pfäffikon
                              #134
                              AW: Tron 5.5
                              Das ist echt ein cooler Heli, für mich nur schade, dass er so klein ist. Naja vielleicht legen sie ja noch einen 700er nach
                              Logo, Goblin, Synergy und Diabolo
                              • Mabuto
                                Supporter XNova
                                • 12.05.2010
                                • 105
                                • Ivo
                                #135
                                AW: Tron 5.5
                                Ich würde keine Aussagen machen die das betreffen, Dario sagte mir ihm liegen sachen vohr, die matt in eine ziehmlich unschöne situation brigen könnten.
                                Nicht vergessen Matt hat die schlammschlacht gestarted nicht Tronhelicopters.
                                Dario is einer der hauptfiguren im tron project.
                                Er weiss von was er spricht.
                                Alle die Dario kennen wissen was für skills er hat.
                                Er wird sich nicht mit seinem Namen dahinstellen wenn er nicht sicher wäre was er macht.
                                Es ist einfach schade das wir uns als Europäer so hinter Matt stellen.
                                Wenn matt nicht gewisse sachen jezt einwilligt wird es nicht schön,
                                Es ist eine absolute katasptrophe was da abgeht!
                                So oder so finde ich sollte man da im Forum über den Heli sprechen von der technischen seite, und ob der jezt ein klon ist wie vohrgeworfen oder nicht!
                                Das andere sollten die verantwortlichen untereinander machen.
                                Ich vestehe nicht warum da so eine hetzjagt gemacht wird, null support für einen Europäer der was macht.
                                Und denen wo der heli nicht zusagt, können ihn ja einfach ignorieren und nicht kaufen.
