MSH Brain Flybarless-System
  • dergringo
    • 03.12.2010
    • 1554
    • timo
    • Hattingen
    #3031
    hi
    Ich war mal so frei und hab ein knapp 2 stündiges (114min) Video über das Brain erstellt. es umfast grundlagen (Mechanik) und schritt für schritt setup. Bin es grade am hochladen. sind 7 Videos. Ich schicke die links wenn es fertig ist. 4 videos sind schon oben. Ich heiße bei youtube dergringo2000 wer vielecht schonmal schauen will.
    • dergringo
      • 03.12.2010
      • 1554
      • timo
      • Hattingen
      #3032
      MSH Brain setup Grundlagen video - YouTube
      MSH Brain setup 1 video - YouTube
      MSH Brain setup 2 video - YouTube
      MSH Brain setup 3 video - YouTube
      MSH Brain setup 4 video - YouTube
      MSH Brain setup 5 video - YouTube
      MSH Brain setup 6 video - YouTube
      Die lesten videos sind noch am hochladen!
      viel spass
      • Uli4G3
        MTTEC/Compass Fieldrep
        Teampilot
        • 19.06.2009
        • 1116
        • Ulrich
        • Bielefeld, NRW
        #3033
        Hi!
        Heute beim anklemmen habe ich die 1.0.29 geladen !
        Weiss jemand was geändert oder aktualisiert wurde?
        Danke, Uli
        Compass Warp 360 Brain
        Compass 6HV Nightfly
        Compass 7HV
        • KU-HELI7
          • 02.02.2012
          • 1847
          • Helmut
          #3034
          Zitat von Uli4G3
          Hi!
          Danke, Uli
          We have just released a new FW (1.1.029) and Software Package (1.0.009) to support this. The main change in the software is that you can now go to the File Menu and Configure your Bluetooth Module. To do this you must be connected to the software via the USB cable with the bluetooth module connected to the Brain and powered up. The bluetooth module cannot be paired or connected to anything to do the programming. After the File Menu selection is made a dialog box will appear that allows you to put in a PIN number and a Name for the unit. Once OK is pressed the PIN and Name will be programmed in addition to setting the baud rate to 115200. This update is designed to work with CRIUS modules so do not use this feature if you are using another module that programs differently. Other modules might work with this but these are not supported by MSH.
          Helmut
          • Wookie
            • 02.04.2010
            • 291
            • Tom
            • Westlich Hamburg
            #3035
            Coole Arbeit.
            Ich pack mich dann heute Abend mit 'ner Tüte Chips aufs Sofa und schau mir den Director's Cut an.
            Bin sowieso gerade am Proggen meines Brains. Ist super gemacht, die Software.
            Protos 500, Brain
            T-Rex 450, GT5
            DX8
            • Peter_S
              Peter_S
              #3036
              Hi Timo
              Arbeitest du jetzt mit Heli Ernst zusammen?
              Spass bei Seite, super gemacht, für so was war´s mal Zeit.
              Peter
              • Uli4G3
                Teampilot
                • 19.06.2009
                • 1116
                • Ulrich
                • Bielefeld, NRW
                #3037
                Hi!
                Ich bin absoluter Brain bzw. TracX fetischist und liebe das Teil einfach!
                Inzwischen läuft auch die Bluetooth Software und alles ist toll!
                Der Warp bekommt demnächst noch den Phasensensor verbaut und dann werde ich dort auch mal den internen Gov. testen !
                Aber eine Sache liegt mir bzw. inzwischen noch 3-4 anderen jungs auf dem Herzen die wir auch mit viel Mühe, testen, prüfen, einstellen etc. nicht richtig weg bekommen!
                Da es bei mind. 4 Piloten ist gehen wir erstmal davon aus das nicht hoffentlich alle 4 den gleichen Steuerfehler machen......
                normale Tic Tocs :
                der Heli wandert immer mehr oder weniger über Roll nach links raus.
                Seiten Tic Tocs mit Nase nach rechts :
                der Heli wandert langsam mit dem Heck nach unten, wenn man die Figur immer weiter fliegen würde käme man irgendwann beim normalen Tic Toc wieder raus!
                Taumelscheibe ist hundert Pro gerade, Schwerpunkt passt
                Hat jemand ähnliches Verhalten beobachten können bzw. einen Tip oder ne Idee wo man ansetzen könnte?
                Vielen Dank, Uli
                Compass 7HV
                • Zoul
                  Compass / MTTEC
                  Teampilot
                  • 26.02.2012
                  • 1057
                  • Herford
                  #3038
                  Habe das gleiche, aber auch keine Idee.
                  • Mike1503
                    • 02.01.2009
                    • 3236
                    • Mike
                    #3039
                    Es ist nur das Heck wenn das weggeht geht er auch im tictoc schräg wegso das man meint es ist roll.
                    Bei mir ist es nur minimal aber damit kann ich leben.Was ich festgestellt habe das Heck geht erst nach einem Moment weg.
                    Quasi bei lang gezogenen Rainbows.
                    Gruss Mike
                    • Zoul
                      Compass / MTTEC
                      Teampilot
                      • 26.02.2012
                      • 1057
                      • Herford
                      #3040
                      Ja, das meinte Uli glaube ich. Dass er durch den Versatz im Heck auch seitlich weggeht dann.
                      Wie viel DMA hast du zyklisch und Kollektiv?
                      • Uli4G3
                        Teampilot
                        • 19.06.2009
                        • 1116
                        • Ulrich
                        • Bielefeld, NRW
                        #3041
                        Die Vermutung hatten wir ebenso und heute einiges an DMA zyklisch und kollektiv versucht, getestet, probiert, gefummelt.
                        Alles nur minimal anders.
                        I und D auch noch mal variiert, aber noch nicht so wie wir es gerne hätten!
                        Mike, wir hatten ja schon auf anderem Wege gemailt das es etwas besser geworden ist, aber im Moment bin ich mit dem Verhalten noch nicht ganz zufrieden!
                        GRuß, Uli
                        Compass 7HV
                        • Mike1503
                          • 02.01.2009
                          • 3236
                          • Mike
                          #3042
                          Du hast also zu wenig DMA wenn deine Finne nach rechts wandert.Meine geht nach links bei DMA 0 und 17,5mm Servo.Ich müsste auch noch bisl drehen das es hält.
                          Weiss jetzt den Wert nicht mehr, jedenfalls den Wert wo steht,entlastet die Heckmechanik das hab ich auch runtergedreht.Wie gesagt wenn ich grade wegschiebe dann geht meine Finne nach links aber erst nach ca.20 m. Ich werde da auch noch bisl probieren.
                          Ich bin bei sowas kein Profi meistens lebe ich mit diesen kleinen Fehlern wenn sonst das feeling passt.
                          Ich bin sonst übelst begeistert mit welch Sicherheit sich das Tracx bei harten oder schnellen Sachen Steuern lässt.
                          Gruss Mike
                          • Tuning Tom
                            Tuning Tom
                            #3043
                            Habt ihrt auch schonmal um eventuelle Steuerfehler auszuschließen das "Stick deadband" etwas vergrößert?
                            • tc1975
                              • 18.08.2008
                              • 6780
                              • MFG Tangstedt
                              #3044
                              ...ich fliege in meinem goblin 700 30/20 für I und D und bei DMA habe ich 40/25.
                              Bei Heck Empfindlichkeit von 42% (nach Brain Anzeige) und 2100rpm
                              RAW 700 / Nitro - @VBar Touch
                              • Uli4G3
                                Teampilot
                                • 19.06.2009
                                • 1116
                                • Ulrich
                                • Bielefeld, NRW
                                #3045
                                Ich glaube ich habe meinen Totpunkt schon mal bis auf 4 erhöht...
                                liess sich schlecht fliegen, war aber immer noch so.
                                gruss, Uli
                                Gesendet von meinem HTC One mit Tapatalk 2
                                Compass 7HV
